ek rear disc question(searched)
Old Aug 14, 2007 | 08:18 PM
perseverance's Avatar
Default ek rear disc question(searched)
ok guys, i was wondering what car's i can get rear disc's from to install on my friends ek coupe? i'm sure i can get it from an em1 but they're hard to find in the boneyard's around here. do integra's work? if so, i found a crx si earlier today with rear disc's that i can pull off which are the same as the integras. all help would be greatly appreciated .thx!!!!!!!
Old Aug 14, 2007 | 08:24 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: ek rear disc question(searched) (perseverance)
Depends on how much work you want to do.
Obviously discs from the same chassis will be the easiest.
Integra rear brakes will be a little bit harder.
And anything else will be even harder.
Integra/civic rear brakes work the easiest and are very user friendly installs.
96-00 ex/si brakes or 94-01 integra brakes will all work fine and maintain ease of install.
zoso's Avatar
I dont think you looked very hard, this question comes up a lot. But yes teggy rear do fit civics. get them off a gsr i am pretty sure they are alittle bit bigger!
Old Aug 14, 2007 | 09:12 PM
so they'll directly bolt up? and yes, i did search and used the faq. i have an eg and i've been looking to help my friend out with his ek. i didn't want to waste money at the boneyard just to find out it won't work. would integra e-brake cables work also???
Old Aug 14, 2007 | 09:20 PM
BlueIntegraBoy's Avatar
Default Re: (perseverance)
Pull the disks off the CRX Si and buy EM1 ebrake cables.
Old Aug 14, 2007 | 10:00 PM
YodajdmEK4's Avatar
I would go with GSR rear disks! Easier to find then EM1 and easy to install if you know how to do it and if you have air tools
Old Aug 14, 2007 | 11:27 PM
zoso's Avatar
Default Re: ek rear disc question(searched) (YodajdmEK4)
Dude just get 94-01 rear disc brake con from craigs list or on here, they go for around 150ish, that comes with everything you need most of the time. And if you know how to do it, its not that hard.
Old Aug 15, 2007 | 04:15 AM
i just did a rear disc brake conversion on my eg... it was a cakewalk. i'm gonna pull some disc's from my local boneyard off 94-01 integra. thx for the help!
Old Aug 15, 2007 | 06:57 AM
SkankyEJ7's Avatar
i have integra brakes and cablkes on my 98 civic coupe it work fine :shrugs:, it was easy to put on too
Old Aug 15, 2007 | 06:59 AM
Ek Forever y0!
Default Re: (SkankyEJ7)
Rear disks
Old Aug 15, 2007 | 07:19 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by perseverance &raquo;</TD></TR><TR><TD CLASS="quote">so they'll directly bolt up? and yes, i did search and used the faq. i have an eg and i've been looking to help my friend out with his ek. i didn't want to waste money at the boneyard just to find out it won't work. would integra e-brake cables work also???</TD></TR></TABLE>
All the answers to your questions could have been found here: https://honda-tech.com/zerothread/1998336
HOMEMADEPOWER
Suspension & Brakes
Jun 14, 2011 09:13 PM
Brianef
Jul 27, 2009 02:59 PM
B16B_coupe
Oct 1, 2006 07:05 AM
yecora
Jul 8, 2006 10:37 AM
griggc
Mar 28, 2006 12:50 AM
