Will this bulb fit?
Old Aug 14, 2007 | 07:41 PM
no1knows908's Avatar
Default Will these bulbs fit?
Will these fit in the corner lights and the bumper lenses?
http://cgi.ebay.com/ebaymotors...idget
Or would I have to go with these?
http://cgi.ebay.com/ebaymotors...yment
Old Aug 14, 2007 | 11:10 PM
MilanoLude's Avatar
Default Re: Will these bulbs fit? (no1knows908)
I see a little diagram on the listing with dimensions that I'm assuming are in mm. I just so happen to have a corner light here on my desk and the bulb opening is just a hair wider than 0.5 inches which is 13mm.
The first bulb you posted is 15mm wide, so it wouldn't fit, I suppose you could widen that opening enough to accomodate a larger bulb size.
The second bulb doesn't have dimensions posted, but it looks smaller.
Is there a reason you want 921 bulbs instead of the stock 194?
Old Aug 14, 2007 | 11:13 PM
Default Re: Will these bulbs fit? (MilanoLude)
My bad I meant 194...
Old Aug 14, 2007 | 11:16 PM
MilanoLude's Avatar
Yeah, supposedly you can replace 194's with that bulb, but they do say they are larger and may not fit. I actually use amber 194 led bulbs and they work just fine.
Old Aug 14, 2007 | 11:19 PM
What style bulb are you using? Single or cluster led?
Old Aug 14, 2007 | 11:31 PM
MilanoLude's Avatar
I'm using the single style right now as corner lights. They are bright, but they do not illuminate the entire housing like regular bulbs do.
I have a pair of the clustered ones with 6 leds in them also. I thought they might illuminate the lens better, but I have yet to give them a try.
ekturbosi88
Honda Fit
Sep 20, 2007 07:16 PM
USDM-EK4*
Jan 5, 2007 02:55 PM
redej878
Honda Fit
May 11, 2006 09:38 PM
bruinman
May 24, 2003 06:08 PM
