Full Tune Up
What do you think a full tune up would run on a 98 gsr? Just want everything under the hood to be solid, some of the stuff I can do myself. Also when does your clutch engage? Mine seems to do it when pedal is just about all the way depressed, adjust?
Do you plan on doing everything yourself or taking it to a shop.
If your taking it to a shop then call a few places up and see what they say. To help the cost purchase all the parts yourself and bring them with you. However, make sure the shop is willing to install the parts you bring in because some shops will not allow that.
As for the clutch try adjusting the pedal.
Ali
Ali
Is there maybe a check list I can run through to see what I need to purchase when the time comes? I know most of the stuff I'm going to need, but would like to double check.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by service »</TD></TR><TR><TD CLASS="quote">
7.5k-22.5k-37.5k-52.5k-67.5k-82.5k mile service
Change Engine Oil & Filter
Check Clutch Adjustment & Fluid Level
Inspect Front Brake Pads, Rotors and Calipers
Inspect Fluid Levels
Adjust Parking Brake
Inspect Exhaust System
Inspect Tire Wear & Set Tire Pressure
Check hoses, belts & coolant level
check wiper blades & windshield washer fluid level
inspect power steering fluid level
inspect transmission fluid level
inspect front suspension & steering operation
rotate tires
15k/45k/75k mile service
Change Transmission Fluid
Replace Fuel Filter
Replace Air Filter
Inspect Front & rear Pads, Rotor & calipers
Inspect all fluid levels
adjust parking brake
inspect clutch operation, adjust freeplay and check fluid level condition
adjust all belts
inspect suspension mounting bolts for tightness
inspect exhaust system
inspect tire wear and set tire pressure
check hoses belts and coolant level
inspect battery and clean terminals
adjust alternator belt
inspect valve clearance
check wiper blades and windshield washer fluid
lube door, hood latches and hinges
rotate tire and balance
inspect and clean spark plugs
inspect cap and rotor
road test
30k/60k/90k mile service
Replace Fuel Filter
Replace Air Filter
Replace Spark Plugs
Replace Distributor cap, rotor and inspect wires
set ignition timing and adjust timing belt
Inspect crankcase emissions
Inspect front & rear pads, rotors and calipers
Replace brake fluid, check hoses & lines
replace clutch fluid, clutch operation, adjust freeplay
adjust all belts & inspect power steering fluid
replace engine coolant & check hoses belts
Ali
rotate tires
Replace Fuel Filter
Replace Air Filter
adjust all belts
road test
Replace Fuel Filter
Replace Air Filter
Replace Spark Plugs
Ali
mkinpwrat12g's
Sep 1, 2005 05:31 PM
