h23 crankshaft in a h22a4 block?
Old Aug 14, 2007 | 02:30 PM
ge_itr's Avatar
Default h23 crankshaft in a h22a4 block?
i have a h23 crankshaft with 50mm mains. is there any customization to make it fit in the h22a4 block with 55mm mains? thanks.
Old Aug 14, 2007 | 02:35 PM
Speedra500's Avatar
Default Re: h23 crankshaft in a h22a4 block? (ge_itr)
not unless you have 5 mm shims, haha. Why don't you look into the f23a crank? IIRC it has 55 mm mains
Old Aug 14, 2007 | 02:43 PM
alterdcreations's Avatar
Default Re: h23 crankshaft in a h22a4 block? (Speedra500)
i will trade you blocks
i have one with 50mm mains
Old Aug 14, 2007 | 02:46 PM
ge_itr's Avatar
Default Re: h23 crankshaft in a h22a4 block? (alterdcreations)
i don't have the a4 block, but i was wondering if it would work. i do need the 50mm one though. will you sell it? pm me. thanks.
Old Aug 14, 2007 | 02:57 PM
98vtec's Avatar
moderator emeritus
welding + align bore = big $$$
ge_itr's Avatar
you gave me a second thought. what do you guys think?
option 1: use my h23 crankshaft and find a h22a1 block for it.
option 2: sell my h23 crankshaft and find a h22a4 block and f23 crankshaft.
the option 2 does give me more stroke but i think it will be pretty hard to find that f23 crankshaft. please help. thanks.
Old Aug 14, 2007 | 03:41 PM
Si Speed's Avatar
What's wrong with the stock crank? Why do you want to change it?
Old Aug 14, 2007 | 04:01 PM
98vtec's Avatar
moderator emeritus
Default Re: (si_speed)
higher stroke
Old Aug 14, 2007 | 04:05 PM
Si Speed's Avatar
Default Re: (98vtec)
Isn't there clearance issues with the oil squirters in the H22 with an H23 crank?
Old Aug 14, 2007 | 04:06 PM
98vtec's Avatar
moderator emeritus
if there is you can bend them out of the way.
Old Aug 14, 2007 | 04:10 PM
Si Speed's Avatar
Isn't that bad?
Why couldn't you just use a longer rod, then change the piston, according to clearance?
I'm kinda talking out of my *** right now, messed up on all kinda medicine from the doctor so just humor me. :/
Old Aug 14, 2007 | 04:12 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si_speed &raquo;</TD></TR><TR><TD CLASS="quote">Isn't that bad?
Why couldn't you just use a longer rod, then change the piston, according to clearance?</TD></TR></TABLE>
why would it be bad?
Old Aug 14, 2007 | 04:14 PM
Si Speed's Avatar
I don't see why Honda would put something like oil squirters there the way they are for no reason. In this case, isn't the XX&gt;98 H22 and H23 bare block the exact same? If so, then wouldn't it be more practicle to do an h23 vtec hybrid?
Old Aug 14, 2007 | 04:19 PM
98vtec's Avatar
moderator emeritus
you still use them, they are just bent so everything clears.
Old Aug 14, 2007 | 04:21 PM
Si Speed's Avatar
fair enough.
Old Aug 14, 2007 | 04:33 PM
117's Avatar
117
If you're talking about using that crank you posted pictures of before, I'd say you need to sh*t can that thing and get a new crank. Quite a few people have told you that using that crank is just asking for trouble.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ge_itr &raquo;</TD></TR><TR><TD CLASS="quote">you gave me a second thought. what do you guys think?
the option 2 does give me more stroke but i think it will be pretty hard to find that f23 crankshaft. please help. thanks.</TD></TR></TABLE>
Old Aug 15, 2007 | 06:36 AM
Speedra500's Avatar
Default Re: h23 crankshaft in a h22a4 block? (117)
It would be less difficult and most likely cheaper to do option 1, however, granted you have alot of money the second option would be pretty cool. Surely someone has done it before, anyone?
Old Aug 15, 2007 | 07:59 AM
PrecisionH23a's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ge_itr &raquo;</TD></TR><TR><TD CLASS="quote">i have a h23 crankshaft with 50mm mains. is there any customization to make it fit in the h22a4 block with 55mm mains? thanks.</TD></TR></TABLE>
What happened to that awesome knife-edged crank you had?
Old Aug 15, 2007 | 09:27 AM
Default Re: h23 crankshaft in a h22a4 block? (PrecisionH23a)
pm sent
price neg
kornerk12
Feb 5, 2007 03:49 AM
superlude01
Dec 3, 2002 12:49 PM
Yuleluder
Sep 18, 2002 08:37 AM
