Installing Header on 91 CRX Si and I a few questions.
Old Aug 14, 2007 | 02:19 PM
Ish's Avatar
Ish
Default Installing Header on 91 CRX Si and I a few questions.
Whats up guys. Im in the process of installing a header on my 91 CRX but one of the bolts to remove the Ex. Manifold shield is being blocked by the AC fan.
My questions are:
1) Do I need to remove the whole radiator to install the header?
2) Where is the radiator drain plug? I can't seem to find it.
3) Do I need to remove the bridge in the front to get to the drain plug?
Any help is greatly appreciated. Thanks in advance.
Old Aug 14, 2007 | 02:22 PM
Pee Wee's Avatar
Default Re: Installing Header on 91 CRX Si and I a few questions. (Ish)
1. you dont need to remove the radiator, which null and voids questions 2 & 3
but the drain plug is on the bottom of the radiator. Its a little plastic plug
Old Aug 14, 2007 | 02:23 PM
Ish's Avatar
Ish
Default Re: Installing Header on 91 CRX Si and I a few questions. (Pee Wee)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pee Wee &raquo;</TD></TR><TR><TD CLASS="quote">1. you dont need to remove the radiator, which null and voids questions 2 & 3
but the drain plug is on the bottom of the radiator. Its a little plastic plug</TD></TR></TABLE>
Thanks. How do I remove that bottom bolt off the exhaust manifold? Should I remove the AC Fan?
Old Aug 14, 2007 | 02:29 PM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ish &raquo;</TD></TR><TR><TD CLASS="quote">
Thanks. How do I remove that bottom bolt off the exhaust manifold? Should I remove the AC Fan?</TD></TR></TABLE>
just stick a freakin 12mm gear wrench on it on take it off! it's really very easy, there is no reason what so ever to remove the ac fan or drain any coolant..........unless you REALLY like wasting time.
Old Aug 14, 2007 | 04:02 PM
Ish's Avatar
Ish
Default Re: Installing Header on 91 CRX Si and I a few questions. (VtecSyndrome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">
just stick a freakin 12mm gear wrench on it on take it off! it's really very easy, there is no reason what so ever to remove the ac fan or drain any coolant..........unless you REALLY like wasting time.</TD></TR></TABLE>
Got it out through the bottom. Thanks
Old Aug 15, 2007 | 10:54 PM
Ish's Avatar
Ish
New problem. My A/C fan won't go in because the header sticks out more than the stock exhaust manifold. Now im not sure if I should just take off the fan or go back to the stock exhaust manifold.
Old Aug 15, 2007 | 10:58 PM
garageEF's Avatar
Default Re: (Ish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ish &raquo;</TD></TR><TR><TD CLASS="quote">New problem. My A/C fan won't go in because the header sticks out more than the stock exhaust manifold. Now im not sure if I should just take off the fan or go back to the stock exhaust manifold. </TD></TR></TABLE>
just ditch the ac fan...better yet...take out all the a/c bullshit
Old Aug 15, 2007 | 11:03 PM
Ish's Avatar
Ish
Default Re: (garageEF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garageEF &raquo;</TD></TR><TR><TD CLASS="quote">
just ditch the ac fan...better yet...take out all the a/c bullshit </TD></TR></TABLE>
Ha. Its nice having A/C but damn it takes so much power from the engine.
Old Aug 15, 2007 | 11:37 PM
garageEF's Avatar
Default Re: (Ish)
Ha. Its nice having A/C but damn it takes so much power from the engine. </TD></TR></TABLE>
can your little d-series really afford to have a parasite like air conditioning? be a man....roll down your window
Old Aug 17, 2007 | 12:10 AM
Ish's Avatar
Ish
can your little d-series really afford to have a parasite like air conditioning? be a man....roll down your window </TD></TR></TABLE>
Yeah I guess. Lol
JacksonD
Apr 2, 2010 01:31 PM
Kusai.Nihonjin.Desu
Apr 9, 2005 04:00 PM
Beave0101
Mar 12, 2003 05:52 AM
turbomonkeyexpress
Feb 25, 2003 07:42 PM
BD7581
Aug 20, 2002 07:34 PM
