ecu upgrade
I believe the stock ECU in the 1G CRX Si is the PA7. The Integra PG7 from the 86-87 Integra will work, but I am not sure if the Integra uses larger injectors or not. You must use the 86-87 ECU because the 88-89 ECU is designed for a distributor with electronic ignition advance. The 86-87 uses vacuum advance just like the 1G CRX Si.
Sonny
Sonny
Big Skeet3817
Engine Management and Tuning
Sep 29, 2009 08:58 AM
