wheel vibration on turns and acceleration
okay my wheel seems like it vibrates alot but i know its not taht cause i got a friend to drive next to me and he said my wheel looked fine but whenever i turn LEFT only and accelerate at the same time it feels like my wheel is vibrating and then also whenever i accelerate after like 3 or 4k rpm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22sedan01 »</TD></TR><TR><TD CLASS="quote">okay my wheel seems like it vibrates alot but i know its not taht cause i got a friend to drive next to me and he said my wheel looked fine but whenever i turn LEFT only and accelerate at the same time it feels like my wheel is vibrating and then also whenever i accelerate after like 3 or 4k rpm</TD></TR></TABLE>
do u have an h22 in your car like your name says? if so what motor mounts are you using? O and Welcome To Honda-tech...make sure to make good friends with the Read Search button in the upper right hand corner
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h22sedan01 »</TD></TR><TR><TD CLASS="quote">thanx and ill use that advice .... yeah i do have the h22 in my civic and the mount kit i have is the Innovative Mounts '92-'95 Civic / '94-'01 Integra Steel Mount Kit H-Series
it could be your mounts that your using...i have a ITR swap in my civic with hasport mounts mine vibrates quite a lot...i dont think its somthing to worrie too much about
well the problem with that is that i had my car running with those mounts for like 3 months now and i didnt have a problem till like 2 weeks ago when i broke the bearings in one of my axles i have non lsd tranny soo the passenger cause my rear braket wasnt mounted good soo my engine moved and then that made my wheel feel like it vibrated alot from the right side.. i changed that and it was alot better but my left side started to do the same thing (my bracket is mounted good soo my motor doenst move at all nemore) but i took the whole axle off and the intermediate shaft and they seemed fine.. they are tight on and dont shake like the other side did before putting a new one in...
A Blue Lude
Nov 1, 2005 11:45 AM
