Rc 310cc Injestors in stock gsr
Old Aug 14, 2007 | 01:22 PM
killacam661's Avatar
Default Rc 310cc Injestors in stock gsr
can i just install the injectors or do i need to upgrade the fuel pump too? how much better will this make a difference in my power? i have a fpr(need a gauge) too.
Old Aug 14, 2007 | 01:34 PM
doood's Avatar
been there done that
Default Re: Rc 310cc Injestors in stock gsr (killacam661)
you will run rich without tuning
you do not need bigger injectors until you start making more than 180-190whp. more fuel without more air is worthless.
come on.... anyone????
BUMP me
Old Aug 14, 2007 | 01:35 PM
PrinceAli132's Avatar
Default Re: Rc 310cc Injestors in stock gsr (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">
you do not need bigger injectors until you start making more than 180-190whp. more fuel without more air is worthless.</TD></TR></TABLE>
Ali
Old Aug 14, 2007 | 01:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">you will run rich without tuning
well it ran like **** with the stockk injectors and the timing was advanced a lil just to run decent. and when i put in the 310cc it ran hella better and had no hesitation. with the stockk injectors its lacking power. and my timing is at 16' btdc.
Old Aug 14, 2007 | 01:39 PM
Maybe your stock injectors need to be cleaned.
Ali
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killacam661 &raquo;</TD></TR><TR><TD CLASS="quote">
well it ran like **** with the stockk injectors and the timing was advanced a lil just to run decent. and when i put in the 310cc it ran hella better and had no hesitation. with the stockk injectors its lacking power. and my timing is at 16' btdc. </TD></TR></TABLE>
you have other problems
Old Aug 14, 2007 | 01:42 PM
you have other problems</TD></TR></TABLE>
like??? i think my cam gears are off a tooth. i have the head pulled off right now and i just ordered a hondata gasket. what all could have been wrong with my car?
Old Aug 14, 2007 | 05:34 PM
kartman5's Avatar
No need for larger injectors on a stock engine. Look somewhere else. Good luck!
.BigSexy
Jun 20, 2007 07:11 PM
SIISFLY
21
May 27, 2005 07:25 PM
hondadriver
Feb 16, 2005 06:38 PM
BLK99VTECR
Oct 17, 2004 06:26 PM
boost3d
Jul 17, 2003 12:06 PM
