92 GSR CODE 15
Old Aug 14, 2007 | 01:09 PM
Tank INC.'s Avatar
Default 92 GSR CODE 15
OK WELL LETS SEE IM RUNNING A CODE 15 WHITCH IS Ignition output signal . PUT A NEW DIZZY ON AND THE CODE IS STIL THERE. I PUT A PUSH START IGNITION ON, COULD THIS CAUSE MY PROBLEM FOR MY CODE?
Old Aug 14, 2007 | 01:13 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: 92 GSR CODE 15 (Tank INC.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tank INC. &raquo;</TD></TR><TR><TD CLASS="quote">OK WELL LETS SEE IM RUNNING A CODE 15 WHITCH IS Ignition output signal . PUT A NEW DIZZY ON AND THE CODE IS STIL THERE. I PUT A PUSH START IGNITION ON, COULD THIS CAUSE MY PROBLEM FOR MY CODE?
Stop yelling! P.S., you can ask multiple questions in one thread.
I would put two and two together here..... hmmmmmmm.
You just changed your ignition to a push button and you're getting a CEL for the ignition output signal...... Just a guess, but I bet you did something wrong or missed something along the way.
jmeyer99
Aug 2, 2007 10:18 PM
