92 GSR A/C
Old Aug 14, 2007 | 12:55 PM
Tank INC.'s Avatar
Default 92 GSR A/C
HOW DO I PUT A A/C SYSTEM INTO A 90 CRX SI. THE MOTOR MOUNT DOES NOT FIT. DO I CUT OFF THE MOTOR MOUNT ON THE BRACKET? NEED SOME INFO.
Old Aug 14, 2007 | 01:11 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: 92 GSR A/C (Tank INC.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tank INC. &raquo;</TD></TR><TR><TD CLASS="quote">HOW DO I PUT A A/C SYSTEM INTO A 90 CRX SI. THE MOTOR MOUNT DOES NOT FIT. DO I CUT OFF THE MOTOR MOUNT ON THE BRACKET? NEED SOME INFO.</TD></TR></TABLE>
Huh? Stop yelling please.
I think what you meant to ask was "I have a 90 CRX Si with a GSR motor and I want A/C, how can I do this?".
You can use the stock A/C system from the CRX, but you need to get a HASport A/C bracket to use the d-series compressor on your B-series motor.
Old Aug 14, 2007 | 09:33 PM
Tank INC.'s Avatar
Default Re: 92 GSR A/C (wiZCo)
ok but i got the b- series backet and compressor,will it be fine if i cut off the motor mount off the bracket ?
Old Aug 15, 2007 | 06:49 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tank INC. &raquo;</TD></TR><TR><TD CLASS="quote">ok but i got the b- series backet and compressor,will it be fine if i cut off the motor mount off the bracket ?</TD></TR></TABLE>
No. You need the D-series compressor that came stock on the vehicle and a D-to-B series compressor bracket adapter made by HASport.
Old Aug 15, 2007 | 06:56 AM
Wes V's Avatar
To expand on wiZCo is saying;
You want the Hasport compressor bracket so that you can use your original compressor. <U>That way you don't have to make up custom AC hoses!</U>
The original hoses will NOT hook up to the "B" motor compressor, or even a lot of other "D" motor compressors.
Wes
Old Aug 15, 2007 | 11:19 PM
Tank INC.'s Avatar
Default Re: 92 GSR A/C (Wes V)
I got the b series a/c and bracket from a friend. custom a/c hoses? from what year and what kind of car do i get them from?
Old Aug 16, 2007 | 07:51 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tank INC. &raquo;</TD></TR><TR><TD CLASS="quote">I got the b series a/c and bracket from a friend. custom a/c hoses? from what year and what kind of car do i get them from?</TD></TR></TABLE>
Did you miss something? I thought we've been pretty clear.
They will need to be *custom* as in custom-made as in you can't just buy them from somewhere if you use the B-series compressor and bracket.
If you use your stock D-Series compressor and a HASport B to D A/C bracket, you can use all the stock components from your vehicle. This is much easier and cost effective.
crx_pooch
Nov 17, 2009 12:06 AM
Coach McGuirk
Nov 2, 2008 02:02 PM
zccrx
10
Dec 27, 2007 09:19 PM
alexb16hb
Feb 15, 2005 10:44 AM
