Where is the trunk door sensor for dc5?
Old Aug 14, 2007 | 12:54 PM
951dc5's Avatar
Default Where is the trunk door sensor for dc5?
warranty is void, i want to fix the back trunk sensor for the door. Its showing on my dash light that the door isnt closed. I know its coming from the trunk door because that little side light on the right of the wall remain lit when trunk is closed. This was another reason why i couldnt find out why my battery keeps dying out. who ever knows, let me know so i can find it if the wire is lose or something. thanks
Old Aug 14, 2007 | 10:39 PM
SuperchargedRSX's Avatar
it must be behind the pannels on the hatch, where u can stick ur hand on the hatch to pull it down theres 1 screw and rest you just pop off
Old Aug 17, 2007 | 12:51 PM
951dc5's Avatar
Default Re: (SuperchargedRSX)
ok i did what you said, unscrew 1 off and pop it off. There are 2 connector there, that goes to the lock/unlock panel. Each connectors had 2 wires. 1st connnector is for unlocking/locking signal. 2nd connector was for signal to tell whether the door is close or unclosed. I check the 2nd connector for power and its not showing any power. i used that signal stick that has negative and power with a light bulb. (dont know what that's call). where else can i find the problem? thanks
curtie94
Mar 18, 2011 07:07 PM
alscrx
Honda Civic (2001 - 2005)
Jan 5, 2009 06:53 PM
Cyber ITR
Jan 18, 2004 01:23 AM
huntarrr
Dec 21, 2003 06:54 PM
tsjeff
Audio / Security / Video
Sep 3, 2003 05:15 PM
