squealing noise.
Old Aug 14, 2007 | 10:52 AM
Jussstin's Avatar
Default squealing noise.
fixed. thanks guys. bolt was missing from alternator
Modified by Jussstin at 4:38 PM 8/18/2007
Jussstin's Avatar
Default Re: squealing noise. (Jussstin)
up up up
Old Aug 14, 2007 | 11:08 AM
Jussstin's Avatar
up
Old Aug 14, 2007 | 11:16 AM
94hatchling's Avatar
I can guarantee you that it is NOT your timing belt that is causing the squeal. If it was, your car would not be running at all.
Check your adjustment bolts for your A/C belt and for your alternator belt. Sounds like you lost one of those that won't allow the belt to stay tensioned, so it squeals.
EDIT: I know this forum moves kind of fast, but DAMN!!! I'm sure if you allowed more than 15min you would have a response. no need to keep bumping so close together. AND, you can accomplish a swap, but can't diagnose what is causing a squealing sound? Good luck anyway.
Old Aug 14, 2007 | 11:29 AM
Jussstin's Avatar
Default Re: (94hatchling)
i dont have ac, so it should be my alternator belt right? it does feel kind of loose when i apply pressur w/ my hand. and as far as the swap thing. this is my third swap by myself. and i cant diagnose a problem like that thats why i H-T. thanks for the fast reply. and i bump the thread because if its at the top its more likely to be looked at.
Old Aug 14, 2007 | 11:39 AM
Default Re: (Jussstin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jussstin &raquo;</TD></TR><TR><TD CLASS="quote">i dont have ac, so it should be my alternator belt right? it does feel kind of loose when i apply pressur w/ my hand. and as far as the swap thing. this is my third swap by myself. and i cant diagnose a problem like that thats why i H-T. thanks for the fast reply. and i bump the thread because if its at the top its more likely to be looked at.</TD></TR></TABLE>
Then yes, it would be your alternator belt. It doesn't have to be very loose to cause a squealing noise. You just want the belt to easily move about 1/4" when at proper tension. If it still squeals, its too loose. If it whines, then it is too tight.
Old Aug 14, 2007 | 11:54 AM
teetee's Avatar
^^^listen to him...he is correct!
Old Aug 14, 2007 | 12:27 PM
dizzzane's Avatar
Power steering pump is what you probably lost the bolt from, that or the A/C compressor. As soon as tension loosened on the belt it will begin to squeal.
Old Aug 14, 2007 | 01:22 PM
projectTeG's Avatar
id say check all the accessory belts.
Old Aug 14, 2007 | 01:34 PM
01_CLtypeS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MilanoRed_dc2 &raquo;</TD></TR><TR><TD CLASS="quote">Power steering pump is what you probably lost the bolt from, that or the A/C compressor. As soon as tension loosened on the belt it will begin to squeal. </TD></TR></TABLE>
he dosent have A/C.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchling &raquo;</TD></TR><TR><TD CLASS="quote">
Then yes, it would be your alternator belt. It doesn't have to be very loose to cause a squealing noise. You just want the belt to easily move about 1/4" when at proper tension. If it still squeals, its too loose. If it whines, then it is too tight.</TD></TR></TABLE>
x2
Old Aug 14, 2007 | 04:05 PM
Jussstin's Avatar
Default Re: (01_CLtypeS)
Thanks for the replys guys. it sounds like its very helpful. i will try this once i get home.
Old Aug 15, 2007 | 09:33 AM
dizzzane's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 01_CLtypeS &raquo;</TD></TR><TR><TD CLASS="quote">
he dosent have A/C.
My mistake. Is most likely alternator as everyone else has said. Good luck.
EGed up from the seat up
May 25, 2010 03:45 PM
supermeister
May 25, 2009 03:09 PM
jdmme09
Feb 15, 2009 06:16 PM
VTECth1s
Aug 30, 2006 10:24 PM
