Fog Lights 93 Civic 2Door
Old Aug 14, 2007 | 10:29 AM
SinsEvil666's Avatar
Default Fog Lights 93 Civic 2Door
I bought a set of fog lights off Ebay, not sure if it matters, but has the swapt to a 00 Si. but yea, fog lights came with hardness...no manual. and cant get them to turn on. i connected the 2 Ground wires-(black), tested ground area before connecting. then i connected, the fog light pin cables to the fog lights. The red cable, which has the relay and the fuse ran to it...i connected it to the battery-(+). then on the other side of hardness has a pin connection for the dashboard fog light switch/button. from the pin connection/button connection it has 2 yellow cables coming out where at the tip they are attached together. i tried connecting the yellow cables to the fuse box...but couldnt get the fog lights to turn on. does anyone know where those yellow wire should go. or any tips on how to test the fog lights if they work, or how to get them to turn on using the dashboard switch.
Modified by SinsEvil666 at 11:55 AM 8/14/2007
ttk3
Lighting
Jan 14, 2008 04:34 AM
benji7288
Dec 29, 2007 08:33 PM
HondaKPX
Jul 25, 2005 10:44 PM
crx1racing
Jun 1, 2005 11:00 PM
4DRmafia
Jul 12, 2004 10:51 PM
