!WTB: SOHC VTEC SWAP
I need Engine, Tranny (ex/si only), if possible harness and ECU.
I DONT need axles (but if they come with it ill take them), linkage, mounts
Also looking for Skunk 2 D-Series Intake Manifold, AEM Fuel Rail, FPR, H22 Throttle Body (Euro R if possible) Adjustable Cam Gear, RC 650cc Injectors, LSD for EX/SI Tranny (D-Series)........Eagle H-Beam Rods, ACL Rod/Main Bearings, Blockguard (thow me some different kinds), ARP Head Studs.
If you have something stupid to say about anything on this list dont bother to post
ive got a d16z6 swap with linkage mounts with inserts , axles,brand new stage 4 clutch, eagle h beams, je pistons 0.10 over, arp head studs, cometic head gasket, 3 angle valve job, new valve seals, it does not have injectors, fpr, ecu, exhaust manifold. it was turbo 4 a short while then i got the hook up on a b series swap so im puttn that in her. im lookn to get 2200$, hell ill even throw in the msd ignition box, coil, and cap! hit me up 1-419-733-6575 josh im located in ohio
Chris22215
May 26, 2009 05:20 AM
tavius44
Jun 23, 2008 01:53 PM
