Tucking some wire...
I started to tuck some wire so it would look cleaner when I drop the new swap in, here is were is some pics, I"ll post more as I keep on going..
no A/C or Heater that's how I roll...
OMG what a mess. I cant stand it when people just let a car sit in the weather
with no cover and then keep working on it as it slowly goes to ****.
Please save that car.
dont tuck them through the fender. what if you need to do some wire work down the rd? do through the inside . heres mine . nothing went through the fender.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ch3mik »</TD></TR><TR><TD CLASS="quote">dont tuck them through the fender. what if you need to do some wire work down the rd? do through the inside . heres mine . nothing went through the fender.
I'm diggin the rad overflow relocation
details please
</TD></TR></TABLE>I'm diggin the rad overflow relocation
details please
</TD></TR></TABLE>it would seem like you would need to extend the wires a lot longer if you did it the way you did. give us more detail on this.
did u guy disconnect the ac wiring harness there is a ground on it and i disconnected mine and now i am getting code 20 also did a wire tuck
Tucking them behind the fender instead of through the framerail also brings up its own problems, at least it did in my case.
Corner lights were a squeeze to get in
Fender liner didn't sit properly.
Tuck em through framerail.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Super Chicken »</TD></TR><TR><TD CLASS="quote">
details please</TD></TR></TABLE>
it fits perfect where the charcoal used to reside. lol.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ilovemyef9 »</TD></TR><TR><TD CLASS="quote">That bay looks clean how long did it take u
.</TD></TR></TABLE>
took me like 5 hours i think. if that . I just had to extend the started wire, at the same time I did the batt relocation so the + was extended of course. the engine harness wires simply went in through the hole the ac hoses came out of . the ac unit under the dash is gone and thats where the fuse box is now. the resistor box is on top of the ALT. and the wires run on the inside above the crank pulley . I rewrapped em all. the pass. side wires run under the mount and behind the headlights. ill get a thread goin soon.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nihad »</TD></TR><TR><TD CLASS="quote">did u guy disconnect the ac wiring harness there is a ground on it and i disconnected mine and now i am getting code 20 also did a wire tuck </TD></TR></TABLE>
I cut the harness off. i dont think any of my grounds are missing.
.</TD></TR></TABLE>took me like 5 hours i think. if that . I just had to extend the started wire, at the same time I did the batt relocation so the + was extended of course. the engine harness wires simply went in through the hole the ac hoses came out of . the ac unit under the dash is gone and thats where the fuse box is now. the resistor box is on top of the ALT. and the wires run on the inside above the crank pulley . I rewrapped em all. the pass. side wires run under the mount and behind the headlights. ill get a thread goin soon.
From: spinning DnB till your head explodes,jersey/philly
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dem0nk1d »</TD></TR><TR><TD CLASS="quote">it's a good idea until someone wacks your car on the side. then shorting out your wiring.
oh well it's the chance you take for perfection.
i ran all my wiring through the fenders then shortly after got slammed by a truck. no problems at all.
anyway my line of work is electrical engineer/wiring technician so im always running wire through tight areas, and for a crx running through the fenders is the best way.
1. put battery in trunk
2. pull fuse box/starter wiring back through the fire wall
3. run headlight/fan wiring through fenders
4. pull resistor box and master cylinder wiring back through firewall. mount resistor box under dash
this is how i did it
I also ate dinner off his valve cover that night as well
