tottally dead battery...but!!!!
Old Aug 14, 2007 | 05:59 AM
rewerbcrx's Avatar
Default tottally dead battery...but!!!!
i had one of the worst days ever with this car since i bought it
bought a brand new battery ..... alt still putting out a lot of power
BUT the battery is now totally dead
after jumping the car and driving it around for about 20 minutes i parked it to see if the battery charged and tottaly dead and now the key won't come out of the ignition... took alt out and brought it down to get tested... still working!!! and now the car won't even turn over
what could this be ? i can't figure it out... the wiring seems fine....
could it be the fuse box under the hood?
i thought somethign was draining it but i don't know what... all grounds look alright
Old Aug 14, 2007 | 06:05 AM
andoxviii's Avatar
Default Re: tottally dead battery...but!!!! (rewerbcrx)
Take it to an electrician that specializes in cars. I would bet that there is something draining the **** out of your battery when it isn't supposed to. Could be a light that is accidentally being grounded to the chassis, or something else of that nature. Someone who specializes in it can find it fast and fix it.
I had this problem with my old probe gt, the light in the trunk was sucking my car of all its juice. Took it somewhere, they identified the problem and fixed it. Never happened again (mind you, they fixed it by breaking the ******* bulb lol)
Good luck.
Old Aug 14, 2007 | 06:10 AM
Luserkid's Avatar
Default Re: tottally dead battery...but!!!! (andoxviii)
Auto or manual? Reason i ask is cause your key not coming out.
Also what year is the car? In your under hood fuse box you have an 80A fuse that connects from the batt to alt. If its blown your alt isnt going to power your batt. Take out your volt meter and check the power while the cars running from the alt to the fuse box then the fuse box to the batt and come back with the results.
Old Aug 14, 2007 | 01:20 PM
rewerbcrx's Avatar
Default Re: tottally dead battery...but!!!! (Luserkid)
manual....
i jumped the starter.... started right up... and ran fine... battery seems to be charging correctly so far... i will find out tomorrow morning...
the key is still not coming out HELP WITH THE KEY PROBLEM
so i had to rig some starter butons and switchs so the car doesn't get stolen.
Old Aug 14, 2007 | 01:32 PM
crazyguy's Avatar
are main relay and all the fuses ok?alt belt loose?
Old Aug 14, 2007 | 01:54 PM
01_CLtypeS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">manual....
so i had to rig some starter butons and switchs so the car doesn't get stolen.</TD></TR></TABLE>
reason i ask is there is an ignition switch recall on some civics...my key got stuck in mine...honda fixed it for free because of the recall
Old Aug 14, 2007 | 02:08 PM
xXSilentScreamXx's Avatar
Default Re: tottally dead battery...but!!!! (01_CLtypeS)
is you steering wheel locked? if so fiddle with it to get it out
i had to do that on my si
Old Aug 14, 2007 | 07:26 PM
rewerbcrx's Avatar
Default Re: tottally dead battery...but!!!! (xXSilentScreamXx)
no steering wheel is not locked.... i can actually turn the car on and off just not to lock position to take the key out
its a 92 civic dx hatch and i would love if thats a recall~!~
Old Aug 14, 2007 | 07:52 PM
NOFX's Avatar
H-T White Ops
I had a key get stuck in my ignition before. It happened a few times with the same key. The car would turn on easily too (it would turn fine, but not come out of the cylinder).
It was a key made by Honda and I'm thinking it needs to be sanded down some.
It took some work to get it out, and while trying my hardest to get it out (jiggling, moving the wheel around, turning the key), it eventually fell out like it was nothing.
This might be the recall he was talking about (it's for 6th gens though).
http://www.tegger.com/hondafaq...e.pdf
Old Aug 15, 2007 | 06:42 AM
rewerbcrx's Avatar
Default Re: (NOFX)
i def do not have a AUTO lol
Old Aug 15, 2007 | 11:11 AM
NOFX's Avatar
H-T White Ops
Default Re: (rewerbcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">i def do not have a AUTO lol </TD></TR></TABLE>
And I don't either. I've never owned an auto. Still happened to me too though.
Old Aug 16, 2007 | 05:49 AM
rewerbcrx's Avatar
Default Re: (NOFX)
this is a factory cut key.... and its stuck... and i have used it before too... and now the son of a biiaatch is not coming out still
Old Aug 16, 2007 | 11:33 AM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">this is a factory cut key.... and its stuck... and i have used it before too... and now the son of a biiaatch is not coming out still</TD></TR></TABLE>
Worse comes to worst, just get a new ignition cylinder and have it re-tumbled to the key that fits your doors and such.
Old Aug 16, 2007 | 11:31 PM
rewerbcrx's Avatar
Default Re: (NOFX)
that sounds exspensive... and this is a DD ... money is tight in my world
Old Aug 16, 2007 | 11:42 PM
NOFX's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rewerbcrx &raquo;</TD></TR><TR><TD CLASS="quote">that sounds exspensive... and this is a DD ... money is tight in my world</TD></TR></TABLE>
It shouldn't be that expensive. Buy a used ignition from a salvage yard. Call some places to see where you could get it re-tumbled and how much it would cost.
civicboy420
27
Aug 20, 2014 07:53 PM
tmoney123
Feb 11, 2010 11:36 AM
UrVtecIsLoud
Dec 7, 2008 12:09 PM
braypunt
22
Sep 11, 2005 09:10 AM
1 Cam Wonder
14
Nov 17, 2004 08:21 AM
