USDM vs JDM Transmission Internals... Same?
Old Aug 14, 2007 | 04:37 AM
Maharajamd's Avatar
Default USDM vs JDM Transmission Internals... Same?
I need to replace the sleeve set on my m2a4. If I buy a set off of Majestic or from the dealer, are the parts the same? Pretty straight forward question.
Thanks guys,
Chad
Old Aug 14, 2007 | 07:37 AM
Maharajamd's Avatar
Anyone? I need to order these parts today!
Old Aug 14, 2007 | 07:42 AM
Lubo_25's Avatar
Default Re: (Maharajamd)
if the gear ratios are identical and its the same make and model of automobile i dont see why not...unless the synchros vary in dimension...when in doubt ask the dealership
Old Aug 14, 2007 | 08:08 AM
117's Avatar
117
The dealership isn't going to know about JDM parts!
I'd imagine they're mostly the same, but there might be some differences. I don't think anyone one the board can answer your question with 100% certainty unless they've rebuilt a JDM trans using USDM parts. I've only rebuilt USDM transmissions myself.
Old Aug 14, 2007 | 08:47 AM
Maharajamd's Avatar
Yea. The dealer definately won't know. I have been searching on a lot of boards and most everyone says that all lude trannys were JDM anyways, so it should work. The gear ratios are not the same though. an M2F4 (usdm) has a shorter 4th and fifth gear then the m2a4 (jdm). I am not replacing the gears though. So I don't know.
Anyone else?
Old Aug 14, 2007 | 09:06 AM
gogunkergorilla's Avatar
steve at hmotorsonline.com can get you a jdm sleeve kit. he's got a contact in japan and goes right to the dealer..
Old Aug 14, 2007 | 09:46 AM
luder94-ChrisA's Avatar
Default Re: (gogunkergorilla)
AFAIK the differences between the JDM & USDM transmissions are in the bell housing & final drive/differential bolt pattern. That's why aftermarket differentials (like the quaife) & aftermarket final drives (like the m-factory) do not fit in the JDM 4th & 5th generation transmissions.
Old Aug 14, 2007 | 09:56 AM
Maharajamd's Avatar
Well I just ordered a new gear and syncro sleeve set. $160 using a honda employees discount.
Hopefully they are the same lol... I will take good pics when I get them in and compare.
Old Aug 14, 2007 | 10:02 AM
$160 are you CRAZY!!! my sleeve kit was less than that even with the shipping from japan to ca and from ca to me. and it was the correct kit for the tranny
and i don't even get a honda employee discount
Old Sep 16, 2007 | 09:16 PM
donz's Avatar
i thought 160 is a pretty good deal.
How sure are people that the quafie LSD doesn't fir the JDM transmission? I have read multiple posts that says it is not a problem for the m2a4
Old Sep 17, 2007 | 05:30 AM
Maharajamd's Avatar
Wow, back from the dead.
The 160 is the sleeve and the gears.
As for the quaife, I have no idea....
B17AGSR
Jun 16, 2009 12:36 PM
imsebtactular
Mar 14, 2008 01:44 PM
Abius
11
Jan 21, 2008 03:51 AM
91efhbsi
Jul 2, 2007 08:48 PM
EngineeredCivic
Mar 20, 2006 07:23 PM
