FS: 1991 Crx Dx. Lots Of Aftermarket. Nitrous. Built D series. 3800........
For Sale 1991 Crx Dx Chassis.
16in White Fondmetal Rims, With Dunlop Sp Sport W-10 Tires. Bolt pattern 114X4
< Minimal "honda" rust on rear quarters, needs sanding and paint, thats all... this is the "bad" side....
< Very Good Tread On Tires... Rims Are Exellent Condition.
Interior:
Basically All Stock Blue Dx Interior, Custom Sub Box, SunPro Tach.
Custom Built Box, 10in. Lightning Audio Subwoofers. Rockford Fosgate Amp, MTX crossover. Battery Relocated Into The Trunk.
10 lb. Bottle Zex Dry Kit, With Purge W/ 3 Jets. NOS Automatic Bottle Opener.
Engine
D16Y5 Block
11.5:1 Compression Pistons.
Stock Crank
D16Y8 Cylinder Head With 3 Angle Valve Job & Stage 1 Brian Crower Cam.
Focuz Cam Gear
Underdriven Crank Pully
Spoon Header
Skunk 2 Pro Series Intake Manifold
BBK 62mm Tb
Aem Cold Air Intake
K&N Cone
Adj. Fuel Pressure Regulator
280 RC Injectors
Accel Wires
OBX 2 Step Colder Plugs.
Si Tranny
Act 6 Puck Clutch
Fidanza Flywheel
And The Exhaust Was Custom Built By A Muffler Shop Its 2 1/4 All the Way Back, Free Flow Cat, Unrestricted Resonator.
It Needs The Valves Adjusted, And To Be Timed, Will Start And Run But Is Out Of Time And The Valve Lash Needs To Be Adjusted. Price Is $3800 OBO.
Located In Spring Grove Il, 60081. Will Arrange For Delivery With A Private Towing Company For A Discounted Fee(A friend of mine Owns A Towing Company). Or You Can Bring A FlatBed Or Trailer.
The Reason For Selling Is I Am Working 40 Hours Weekly And Dont Have Time Or Money To Finsh This Car... Emal @ Blacklabel46@hotmail.com OR PM... Bump If You Look.
Thanks For Stopping By.
Ken.
Interior:
Engine
D16Y5 Block
Stock Crank
Focuz Cam Gear
Spoon Header
BBK 62mm Tb
Aem Cold Air Intake
K&N Cone
280 RC Injectors
Accel Wires
Si Tranny
Act 6 Puck Clutch
Fidanza Flywheel
Ken.
el bumpo for a friend, i even took that second pic.........very well kept car as you can tell from the interior. it used to suprise me for being on a sohc slammer. someone pick this up!
