crx headlights
Old Aug 13, 2007 | 10:53 PM
tribalbreak's Avatar
Default crx headlights
hey guys i got a stupid question. I found a Drivers side headlamp for a 91 crx. i have an 89 and i wanted to know the difference. most places show 88-89 and then a 90-91 when talking about headlamp assemblies. i found it real cheap so im hoping it will work. is it any different? will it fit my car? any help cuz my drivers side light is burnt out due to an exploded bulb.
Old Aug 14, 2007 | 12:46 AM
Default Re: crx headlights (tribalbreak)
bump i need some help
Old Aug 14, 2007 | 03:43 AM
Mugencrxsir1's Avatar
If I recall the headlights are the same for 88-91 USDM crx's, corner lights are the only thing that's different from 88-89, and 90-91. Someone correct me if I'm wrong.
Old Aug 14, 2007 | 07:23 AM
crx_si-r's Avatar
Default Re: crx headlights (Mugencrxsir1)
yea headlamps are the same u just have to swap out the actaul headlight brackets. and ur good to go.
Old Aug 14, 2007 | 11:05 AM
thanks guys im gonna go ahead and buy that headlamp then
Old Aug 14, 2007 | 02:22 PM
Ish's Avatar
Ish
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tribalbreak &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys im gonna go ahead and buy that headlamp then</TD></TR></TABLE>
Let me know how it goes. I'm thinking of buying some 89 headlights that I need for my 91.
Old Aug 14, 2007 | 02:34 PM
VtecSyndrome's Avatar
Default Re: crx headlights (Ish)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ish &raquo;</TD></TR><TR><TD CLASS="quote">
Let me know how it goes. I'm thinking of buying some 89 headlights that I need for my 91. </TD></TR></TABLE>
Yes all 88-91 Civic/CRX headlights are the same. The headlight brackets are diff from 88-89 to 90-91 and you gotta run the same corner lights as the HL brackets you run due to the way they mount up. If you don't want to change your corner lights out then just replace the headlight it's self leaving the HL bracket alone.
90 JDM EF8
May 20, 2006 10:30 AM
djsire
Jul 17, 2005 09:32 PM
HmgLauj69
23
May 14, 2005 06:53 AM
B.S._TURBO
Nov 15, 2004 02:50 PM
sm00thk0zz
Sep 13, 2004 11:06 AM
