Water Pump...HELPPPPP!!!!!
Hey guys, my water pump seems to be messed up making my thermostat and my rad to blow up
, anywho i was wondering where is the thermostat, i looked in this site but couldnt find a pic of it along with the water pump.. i was wondering if any of u guys could help me find where it is, a pic would be great, i lost my manual. or even if u could direct me to a site that shows it.
i looke here and found things related to the cam shaft, pulleys and engine build ups, so on and on.. but not what im looking for
help please
thankx in advance
, anywho i was wondering where is the thermostat, i looked in this site but couldnt find a pic of it along with the water pump.. i was wondering if any of u guys could help me find where it is, a pic would be great, i lost my manual. or even if u could direct me to a site that shows it. i looke here and found things related to the cam shaft, pulleys and engine build ups, so on and on.. but not what im looking for
help please
thankx in advance
follow the lower radiator hose from the radiator. where it connects to the motor is where the thermostats is located. the waterpump will be on the driver side under the covers for the timing belt. you cannot see it without taking out the top cover for the belt. once the cover is off, the first gear on the right that you see on top will be the water pump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SYTFU Tommy. »</TD></TR><TR><TD CLASS="quote">follow the lower radiator hose from the radiator. where it connects to the motor is where the thermostats is located. the waterpump will be on the driver side under the covers for the timing belt. you cannot see it without taking out the top cover for the belt. once the cover is off, the first gear on the right that you see on top will be the water pump. </TD></TR></TABLE>
the TOP radiator hose is the hose you follow. the thermostat housing has 3 10mm bolts on it.
awesome, thankx a lot guys. now i have to get teh parts and get them in my car cuz taking a bus after owning ur car is a b*tch
thanx a mill people.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwlee7ucla »</TD></TR><TR><TD CLASS="quote">
the TOP radiator hose is the hose you follow. the thermostat housing has 3 10mm bolts on it.</TD></TR></TABLE>
the top radiator hose goes from the radiator to the head. the lower one leads to the thermo.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">
the top radiator hose goes from the radiator to the head. the lower one leads to the thermo.</TD></TR></TABLE> i have a 94 gsr, for me its the top. I recently changed my thermostat. maybe its different for your car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwlee7ucla »</TD></TR><TR><TD CLASS="quote"> i have a 94 gsr, for me its the top. I recently changed my thermostat. maybe its different for your car.</TD></TR></TABLE>
my 95 b18c1 has the thermo at the lower radiator hose
You better look again. Your upper radiator hose connects to the head and has a bleeder screw on it.
The thermostat housing is located at the engine-side of the LOWER radiator hose. All Honda B and D series engines are set up in this manner.
<--- has flushed coolant and changed thermostats several times.
The upper hose attaches to #6 above, which bolts to the head.
The lower hose attaches to the thermostat cover #5, which bolt to the thermostat housing #7, which has a pipe behind it going over to the water pump.
