blox A cams right now, upgrade to blox B or other stage 2 cam?
Old Aug 13, 2007 | 10:09 PM
DC4R27's Avatar
Default blox A cams right now, upgrade to blox B or other stage 2 cam?
I have blox type A cams right now on a b18c1 with itr pistons. Ive been considering upgrading to the blox B or other stage 2 cam. My question is, will upgrading to a stage 2 cam increase some of my low end? Top end will increase too?
Old Aug 13, 2007 | 10:22 PM
cartune network's Avatar
Default Re: blox A cams right now, upgrade to blox B or other stage 2 cam? (DC4R27)
it all depends on the size of the camshaft. and if they are using a larger primary lobe than stock. ull gain some low end but most of the gain is gonna be mid and alot of high. whats ur compression ratio at with itr pistons?
Old Aug 13, 2007 | 10:28 PM
DC4R27's Avatar
Default Re: blox A cams right now, upgrade to blox B or other stage 2 cam? (cartune network)
im at 11.0 cr right now. I want some more power, but my concern is with the midrange. I like having high end as well, but my car is a street car, not a dragger. I have all the bolt ons:
aem cai
68mm tb
oem gsr im ( i also want to get a different im, i know its restricting me a lot)
blox type A cams, cam gears
jdm itr 4-1 header
test pipe
jdm itr 2.36 exhaust
I was tuned at Church automotive, i pulled 192whp/148tq. My plans are to upgrade my intake mani and I am considering going with bigger cams. any advice is greatly appreciated.
Old Aug 13, 2007 | 10:40 PM
well on my itr i made a huge gain from stock by going with buddy club spec 3 cams which imo are perfect for daily driving (but u will need new valve springs and retainers) and the occasional rip down the highway. the best way to make power is by porting the head, getting cams, port matching ur intake mani, and a good header with a 2.5 inch collector and a true 2.5inch exhaust.
Old Aug 13, 2007 | 10:48 PM
and a good tune.
Old Aug 15, 2007 | 07:49 PM
1.8L_allmotormilitia's Avatar
damn churches sure does tune real good. 192whp with those mods is good.
Old Aug 16, 2007 | 09:58 PM
DC4R27's Avatar
Default Re: (1.8L_allmotormilitia)
yeah, i have a mild build right now. i like my setup, its quiet yet still aggressive, but a little more power wouldnt hurt. I know my oem gsr intake mani is really restricting me, but what do you guys think about my oem itr cat back? its 2.36, same diameter as a lot of aftermarket exhausts out there. Do you think ill notice any gains if i went with a 2.5 inch exhaust?
Old Aug 16, 2007 | 10:07 PM
DC4R27's Avatar
Default Re: (DC4R27)
i actually have an ebay 2.5 inch exhaust in my garage right now, if i slapped it back on,
1. would it give me gains over my 2.36 oem itr catback
2. would it f*ck up my tune and make me run lean and put my engine in danger?
Old Aug 17, 2007 | 12:16 AM
4-1 header, 2.5" straight pipe, 2.5" es oval axle back, NO CAT, skunk2 intake manifold and you will make more power.
Old Aug 17, 2007 | 12:36 AM
and annoy the hell out of every one else on the road lol a header with a 2.5inch collector and a true 2.5inch exhaust will make more power.
Old Aug 17, 2007 | 01:37 AM
Default Re: (cartune network)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cartune network &raquo;</TD></TR><TR><TD CLASS="quote">and annoy the hell out of every one else on the road lol a header with a 2.5inch collector and a true 2.5inch exhaust will make more power.</TD></TR></TABLE>
Old Aug 17, 2007 | 11:22 AM
DC4R27's Avatar
yeah, the reason i opted for the itr catback is because its oem sounding, yet its a 2.36 diameter. I had my 2.5 catback on for a few months, im using the ebay twin loop, and it was soooooo f*ing loud i had to take it off. I know getting a skunk or blox intake mani is something thats very realistic for me on my next to do list, but i mean, will slapping on my exhaust again make noticeable gains? Noticeable is the key.
Old Aug 17, 2007 | 11:27 AM
DC4R27's Avatar
the cost for bigger cams which includes getting new valvesprings, retainers and intake mani kind of has me wondering if i should just go with some itbs instead. My friend has a hookup on some toda knock offs that will be cheaper to do vs. all those other mods i just mentioned up top. I have the blox type A's currently, and they make good power. i hear they are supposed to be equivalent to s2s1 cams, and buddy clubs, though i hear buddy clubs make good midrange. If im going to have to upgrade springs and retainers, i might as well step up to a bigger cam since i have the 11.0 compression to match a bigger cam right?
Old Aug 17, 2007 | 03:24 PM
if ur gonna do springs and retainers i would definitly go with a bigger cam. the bc3's are pretty big but will compliment ur comp ratio very nicely. i would seriously recommend a port though. get the head ported and port match th intake mani. a bigger throttle body would help too. but must be matched up to the intake mani.
Old Aug 17, 2007 | 03:28 PM
peacexisxfree's Avatar
192 whp? not to be a dick, but that seems generous for that set up.
Old Aug 17, 2007 | 03:36 PM
DC4R27's Avatar
Default Re: (peacexisxfree)
maybe you should forward your question to shawn church buddy.
Old Aug 24, 2007 | 09:43 AM
DC4R27's Avatar
what intake mani will give me good mid range power? and does anyone know the diameter in mm of the opening on the blox intake mani? Im considering the blox intake mani cuz its so cheap.
Old Aug 24, 2007 | 10:39 AM
Gong Show's Avatar
Here's a manifold test my buddy did awhile ago. Check it out.
https://honda-tech.com/zerothread?id=2012979
I'd be happy with thos numbers you have. I'll be doing pretty much close to the setup u have.
GSR motor
Mild P&P
JDM ITR or P30 pistons
Bubby Club 2layer head gasket
Blox type A cams
Skunk2 manifold matched up to TB
64 or 65mm TB
CAI
DC 4-1 header
2.5 exhaust
tuned on crome
I'm too in search of a cam that will perform more on the low to mid, and have decent top end. I don't plan to rev my car any higher than 84-8500rpms. I've been told that BC3's have good midrange.
Old Aug 24, 2007 | 05:21 PM
DC4R27's Avatar
Default Re: (Gong Show)
yeah, i read that thread, but no one has info on the blox. i know i can get it for like 150 on ebay, which is pretty damn cheap, but i want to hear from people who have similar mods, and switched over to the blox intake mani.. Will it really change my power band around a lot, cuz i had a blox intake mani on my LS motor, and it made it feel like ****.
Old Aug 24, 2007 | 05:25 PM
DC4R27's Avatar
yeah, i read that thread, but no one has info on the blox. i know i can get it for like 150 on ebay, which is pretty damn cheap, but i want to hear from people who have similar mods, and switched over to the blox intake mani.. Will it really change my power band around a lot, cuz i had a blox intake mani on my LS motor, and it made it feel like ****. I dont want to lose any of the low end that i have right now, but if i can gain some low end, AND get some high end also, ill totally get it
Old Sep 7, 2007 | 04:41 PM
civic4g63's Avatar
i got it on my gsr good top end same as skunk 2
Old Sep 7, 2007 | 07:43 PM
Gong Show's Avatar
Default Re: (civic4g63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic4g63 &raquo;</TD></TR><TR><TD CLASS="quote">i got it on my gsr good top end same as skunk 2</TD></TR></TABLE>
from the looks of it, I was going to say it would probably be similar to a skunk2 mani. I would just spend a lil extra and get the manifold in the link. It's tested and proven results in ya face y0. Or upgrade to a better header.
Modified by Gong Show at 11:20 AM 9/10/2007
Old Sep 9, 2007 | 09:24 PM
redDAinteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4R27 &raquo;</TD></TR><TR><TD CLASS="quote">im at 11.0 cr right now. I want some more power, but my concern is with the midrange. I like having high end as well, but my car is a street car, not a dragger. I have all the bolt ons:
aem cai
68mm tb
jdm itr 4-1 header
test pipe
I was tuned at Church automotive, i pulled 192whp/148tq. My plans are to upgrade my intake mani and I am considering going with bigger cams. any advice is greatly appreciated.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by peacexisxfree &raquo;</TD></TR><TR><TD CLASS="quote">192 whp? not to be a dick, but that seems generous for that set up.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4R27 &raquo;</TD></TR><TR><TD CLASS="quote">maybe you should forward your question to shawn church buddy.</TD></TR></TABLE>
He is right, it is VERY generous, but only because churches uses a dynapack which typically reads higher than a standard dyno jet. So with all their calculations on their page you would be able to calculate your real wheel HP. So your car is producing 192whp on a dynapack which should come out to around 208hp to the flywheel, but on a standard dynojet, you should be around 180-184WHP which would mean your making around 201hp to the flywheel.
This is all on their website http://home.earthlink.net/~spc....html
del_sol583
10
Apr 22, 2009 08:13 AM
gilou bilou
Apr 5, 2006 10:17 PM
Pnoyej6
Sep 19, 2004 10:30 AM
IcemanRR
Jan 29, 2004 09:14 AM
G3gsr
Feb 2, 2003 12:38 PM
