did a jdm h22a swap into a 4th gen n car won't start!! help
Old Aug 13, 2007 | 08:50 PM
vietdragontekx's Avatar
Default did a jdm h22a swap into a 4th gen n car won't start!! help
we did everything correctly, the car was originally the SI vtec 4th gen model so the jdm h22a is obd1 too, we plug everything up, car crank and sometime it want to start up but it won't. the motor came out of my friend h22 integra and it start up and run perfectly when we took it out.
i know that the jdm h22a use an internal distributor, but the 4th gen prelude used a external so we just took the 4th gen h22 external distributor and slap it on.
we check every wires, replace spark plugs, spark wires. even replace main relay.
Car crank and sometime want to start but won't vottage on battery is good.
Old Aug 13, 2007 | 09:10 PM
Pullig's Avatar
Default Re: did a jdm h22a swap into a 4th gen n car won't start!! help (vietdragontekx)
did u make sure that the ground wire is grounded out at the thermostat housing ? and that every ground is hooked up
Old Aug 13, 2007 | 09:19 PM
Default Re: did a jdm h22a swap into a 4th gen n car won't start!! help (Pullig)
yep thermostat, valve cover, tranny, block, yeh im pretty sure..
Old Aug 14, 2007 | 12:54 AM
NVM it fix
Old Aug 14, 2007 | 12:59 AM
superturboprelude's Avatar
yea i know i fixed it haha
MadCityLude
Sep 22, 2006 09:45 AM
JDMH22AEG6
Jul 24, 2005 04:18 PM
h22PreludeSi
Mar 27, 2005 02:49 PM
OzWolfbane
Jan 11, 2005 02:38 AM
wildrice
Jul 7, 2003 08:37 AM
