rear seats in an rsx
im gonna trade my lether seats for some base rsx seats cuz i live in hell...literally. so i was wondering how you take off the rear seats...where are the bolts located...i would go and check myself but its like 110 outside...thanks
put down your back seats, lift up that cloth or what ever it is that is just get stuck on the bottom of the back seats from trunk part, and you will see about 6 bolts, 2 on left side.. 2 in middle and 2 on right side on the bottom of the seats. Passanager side seat will come out and then there will be the last bolt in middle that the seat was blocking, you take that off and the seat will be come out, and there you will see 1 bolt that holds the seat that you sit on... and front part you just lift up to get it off.
Good luck!
Good luck!
i gotem from someone in artesia cali. i was alsp suprised becuz ive posted my seats before but noone ever wanted leather....the only downside is that its from a base 03' and they have less cushion. be aware that also you lose the passenger side seat airbag becuz there are different connections for some reason and your stock bose amp will be not mounted neatly.so im trying to find a way to mount that and also i need to get an obd2 sensor to clear my airbag thing on my speedometer. overall seats are comfy and i dont have to burn in palm springs
o and it's only temporary until i can afford brides or what not.
kasimmmmm
Oct 26, 2005 09:56 AM
137
Apr 27, 2005 07:49 PM
barefootbilly
Mar 31, 2004 06:39 PM
