EF pedal set into DA
Old Aug 13, 2007 | 06:14 PM
whiteboy4life74's Avatar
Default EF pedal set into DA
Would an EF manual pedal set bolt into my DA?? im doing an auto to manual conversion. Also would an EF clutch cable be the same length as a DA clutch cable?? Thanks
Old Aug 13, 2007 | 06:19 PM
PACT man's Avatar
Default Re: EF pedal set into DA (whiteboy4life74)
I dont't remeber for sure but I think the pedals are the same. The clutch cable I know is different, you can't use the EF cable.
Old Aug 13, 2007 | 06:24 PM
im putting a h22 in my DA and some people say that the DA clutch cable barely reaches so does do know if the prelude clutch cable is longer???
Old Aug 13, 2007 | 07:54 PM
DA9ReMiX's Avatar
the EF nd DA pedals are the same.. diff clutch cable tho.. but if you are using the H22 tranny... you're gonna have to go hydro anyways unless you get the H to B kit nd use a cable B series tranny
Old Aug 14, 2007 | 03:49 AM
Default Re: (DA9ReMiX)
im gonna using the hydro to cable conversion but it is on the trans so u have to run a clutch cable to it.
djnikko
Jan 2, 2015 07:01 AM
EJ1Turbo
Dec 5, 2008 08:14 AM
redboy183
20
Jan 1, 2008 07:05 PM
integrawow
Nov 15, 2006 11:55 PM
vtechrex
Dec 1, 2005 11:16 AM
