Changing my back brakes
Old Aug 13, 2007 | 03:41 PM
Silencio's Avatar
Default Changing my back brakes
i have previously change my back brakes on my '92 honda civic ex successfully. But i havnt been able to do it this weekend . Any one can help me out ?
Old Aug 13, 2007 | 03:43 PM
94eh2's Avatar
Default Re: Changing my back brakes (Silencio)
not to thread jack you ..but im on the same boat can someone help the both of us on how to change the back drum brakes?
Old Aug 13, 2007 | 03:44 PM
hatchling37's Avatar
Are they drum or disc?
Old Aug 13, 2007 | 03:51 PM
Silencio's Avatar
Default Re: Changing my back brakes (hatchling37)
theyre disc
Old Aug 13, 2007 | 03:54 PM
ekb16's Avatar
just remember that the caliper piston screws in instead of pushed in
Old Aug 13, 2007 | 04:01 PM
EL Vap133's Avatar
What have you not been able to do?
Silencio's Avatar
Default Re: (ekb16)
could u elaborate on that part ... the previous times i remember i pushed it wit a long flat screwdriver ( i know low tech put it work) ... since my posts are limited to only five ... i'll just tell the story... so far wat i've done is u know obviously remove the tire n after tat i remove the old inner brake n leav the outer old brake to push it with the screwdriver to compress the piston back into the caliper... and thats where my problem is
Old Aug 13, 2007 | 04:55 PM
Targa250R's Avatar
be professional
Default Re: (Silencio)
You don't "push" rear caliper pistons when they have an integrated parking brake mechanism. You turn them.
Rear calipers are also notorious for freezing up. Unfortunately, remans are a bit expensive (usually about $85 apiece) due to the complication of the parking brake, but parts don't last forever.
pilotboy
Apr 14, 2018 04:31 PM
odidipissuoff
Suspension & Brakes
Dec 16, 2009 09:43 AM
ekb16
Suspension & Brakes
May 3, 2006 08:39 AM
Poop111444
May 23, 2004 11:20 AM
Inigo Montoya
Mar 1, 2004 09:12 AM
