CRX Door Question.
Old Aug 13, 2007 | 02:55 PM
Nihilus's Avatar
Default CRX Door Question.
Will 1988 CRX Si doors (whole assembly) swap onto a 1990 CRX Si? I already know about the seatbelts being door mounted on 89-91 CRX Si's but I have been looking around to find out if I can simply swap some 88 Si doors on my 90 Si. Thanks in advance.
Old Aug 13, 2007 | 03:33 PM
Red_ED8's Avatar
Default Re: CRX Door Question. (Nihilus)
It will swap over fine but it will look weird because the 88-89 have different moldings then the 90-91.
Old Aug 13, 2007 | 03:37 PM
SIred91's Avatar
Rainman
Default Re: CRX Door Question. (Red_ED8)
They will fit, but a few things will be wierd.
Old Aug 13, 2007 | 04:37 PM
VtecSyndrome's Avatar
Default Re: CRX Door Question. (SIred91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SIred91 &raquo;</TD></TR><TR><TD CLASS="quote">They will fit, but a few things will be wierd.</TD></TR></TABLE>
x2, like the moulding on the door mainly once you deal with the seatbelt differences. but it will physically bolt up to your 90-91. I personally would like to convert to the 88s one day due to the lighter wieght and the fact the doormounted seatbelts are actually way more unsafe than the 88 style and the "everywhere else in the world but here style" for that matter.....damn USDM DOT!!!
Old Aug 13, 2007 | 07:01 PM
JUN.'s Avatar
Default Re: CRX Door Question. (VtecSyndrome)
The mouldings CAN be swaped over............
The problem is how are you going to mount the 88 seat belts to your 90-91 EF?
maybe heilcoil
Old Aug 14, 2007 | 03:07 AM
Default Re: CRX Door Question. (JUN.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN. &raquo;</TD></TR><TR><TD CLASS="quote">The mouldings CAN be swaped over............
maybe heilcoil </TD></TR></TABLE>
been done before, need a good welder though.
Old Aug 14, 2007 | 02:59 PM
Nihilus's Avatar
I knew about the differences in the moldings but I also knew that they were interchangable. As for the seatbelts, I have that taken care of already. Well my main question has been answered, however, is that it? The seatbelts and moldings, I mean, being the only problems?
As the other guy stated, the huge difference in door weight is my main reason for wanting to swap over the doors. However, I also wanted to be able to rock the 88 door panels for clearance issues with the autopower rollbar I am ordering soon. And the rollbar plays in with my seatbelt issue.
I was able to weigh my CRX a day ago and came in at 1915 with no driver. I want to break 1850 and swapping doors would be a help with that...
Old Aug 14, 2007 | 04:27 PM
Phshorty's Avatar
i have a 90 si with the door mounted seat belts, but last month i striped my interior to clean everything like a neat freak and found that my chasis had to mounting locations for the 88 seat belts with the threds in place.. im guessing just look and see if you get lucky.
Old Aug 14, 2007 | 05:05 PM
Default Re: (Phshorty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phshorty &raquo;</TD></TR><TR><TD CLASS="quote">i have a 90 si with the door mounted seat belts, but last month i striped my interior to clean everything like a neat freak and found that my chasis had to mounting locations for the 88 seat belts with the threds in place.. im guessing just look and see if you get lucky.</TD></TR></TABLE>
I have heard of 1/2 the holes being threaded but not all. I think there are three holes per side If I remeber correclty, are you saying all 6 holes were threaded?? I need to check mine but that would be sweet as hell if all 6 were threaded (though not holding my breath).
Hym3n
Jan 13, 2009 09:31 AM
camo_crx
Dec 5, 2005 06:47 PM
mstolars
Oct 14, 2005 12:39 PM
dtown_racer
Feb 21, 2005 04:35 AM
tgreaves
Jan 12, 2004 11:55 AM
