question
will the rear lower control arms off a eg or ek civic fit and ef civic
at the moment i have the standard jdm ef9 lower control arms which fit the rear shocks with the eye hole instead of the fork shocks but i want to convert it to be able to take the usdm shocks with the fork shocks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mystic-s »</TD></TR><TR><TD CLASS="quote">will the rear lower control arms off a eg or ek civic fit and ef civic
at the moment i have the standard jdm ef9 lower control arms which fit the rear shocks with the eye hole instead of the fork shocks but i want to convert it to be able to take the usdm shocks with the fork shocks</TD></TR></TABLE>
Dude it is SOO hard to understand your broken english and confusing sentence but I think I know what your asking. If you want to be able to run the stuts with the fork then you need 89-91 rear lower control arms (EG or EK won't work) from any other civic/crx an get the Si's if you wanna run the Si sway bar. sounds like you already have the 88 LCAs and you either need to get 88 crx rear struts or the 89-91 EFs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mystic-s »</TD></TR><TR><TD CLASS="quote">so i would prob be better of getting after market one's</TD></TR></TABLE>
aftermarket what? control arms I assume?
