I Need A New VTEC Head. Which One Should i buy?
Old Aug 13, 2007 | 12:49 PM
killacam661's Avatar
Default I Need A New VTEC Head. Which One Should i buy?
i have a gsr and the #4 cylinder spark plug got stripped and i need to buy a new head. i have a 95 b18c1. which is the best head to throw on it?thanks
b16a?
b16a2?
gsr?
Which one is better for my Setup??
Old Aug 13, 2007 | 12:52 PM
adamrich33's Avatar
Default Re: I Need A New VTEC Head. Which One Should i buy? (killacam661)
if thats all that is wrong with it just take it off and have a machine shop rethread it for you,
Old Aug 13, 2007 | 12:56 PM
Default Re: I Need A New VTEC Head. Which One Should i buy? (adamrich33)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adamrich33 &raquo;</TD></TR><TR><TD CLASS="quote">if thats all that is wrong with it just take it off and have a machine shop rethread it for you,</TD></TR></TABLE>
i did but the 14mm tap threaded it too big and the sparkk plug and sleve go all the way through the threads. and they said it was too close to the valves and they wouldnt be able to weld it cuz the ycant get up in there. i was like WTF. i am going to takke it to another shop in LA. GAY *** SPARKK PLUG THREAD TAPPER
Old Aug 13, 2007 | 02:17 PM
kraig8's Avatar
see if they can put a helicoal in that should fix it.
Old Aug 13, 2007 | 07:05 PM
adamrich33's Avatar
Default Re: (kraig8)
thats what im saying i dont know why a helicoil wouldnt work
Old Aug 15, 2007 | 04:13 PM
lgda92gsr's Avatar
Default Re: (adamrich33)
i dont think u can use a helicoil becouse all it really is, is like a spring that get screwed in backwords. it will not seal it up and when u go to change ur spark plugs the coil will come out with it. i would say get a new head. what happens if the helicoil falls out in ur motor u will be lookin for more than a head when that happens!!!
Old Aug 15, 2007 | 05:51 PM
Dogginator's Avatar
Daisy... Daisy...
You could weld the hole and retap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lgda92gsr &raquo;</TD></TR><TR><TD CLASS="quote">i dont think u can use a helicoil becouse all it really is, is like a spring that get screwed in backwords. it will not seal it up and when u go to change ur spark plugs the coil will come out with it. i would say get a new head. what happens if the helicoil falls out in ur motor u will be lookin for more than a head when that happens!!!</TD></TR></TABLE>
The threads do not seal a spark plug.
Old Aug 15, 2007 | 06:17 PM
BUMP
Old Aug 15, 2007 | 07:21 PM
95RSdrag's Avatar
I say go with the GSR head. I've only read about b16 and how they don't provide as much power as the GSR. Correct me if I'm wrong.
Old Aug 15, 2007 | 08:03 PM
deftonerider's Avatar
i read in a honda tuning that the gsr head has a better design for na cars and the b16/type r is best for boost
something to do with the port designs
so i hope that helps in you decision
also how did you strip the thread??? how much did you tighten it
Old Aug 15, 2007 | 08:06 PM
JDMDAEK's Avatar
GO with the a2 vtec screams in that... or go big money and get a B16b or type r
Old Aug 15, 2007 | 08:44 PM
CeReal's Avatar
Default Re: I Need A New VTEC Head. Which One Should i buy? (JDMDAEK)
i have bought a b16a2 from h-t. it is for sale. its complete except for not having a distributor. pm me to see.
Old Aug 15, 2007 | 08:57 PM
PACT man's Avatar
Default Re: I Need A New VTEC Head. Which One Should i buy? (CeReal)
The best B16 or ITR that you can afford and then use your GSR cams if it didn't come with CTR's or ITR's.
Old Aug 15, 2007 | 11:51 PM
1.8L_allmotormilitia's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMDAEK &raquo;</TD></TR><TR><TD CLASS="quote">GO with the a2 vtec screams in that... or go big money and get a B16b or type r</TD></TR></TABLE>
who gives a **** if it screams, if he slaps that b16 head on the gsr block hes going to lose compression.
Old Aug 16, 2007 | 07:03 AM
Rikter's Avatar
I've got a complete vtec (B16) head for sale. Intake, sensors, tps, throttlebody, type-r cams, vtec solenoid, aem cam gears, etc. PM me if interested.
-Rik
Old Aug 16, 2007 | 08:34 AM
CeReal's Avatar
Default Re: (Rikter)
mine is stock with obd-2 and $420 and complete and used you can look to inspect it..er bring tools.. you get your money back for shipping? expletive it, its over. im new, where is the for-sale forum.
Cereal
Modified by CeReal at 9:44 AM 8/16/2007
hrtagrm
Honda S2000
Sep 30, 2008 07:09 AM
killacam661
Aug 13, 2007 04:59 PM
dc4rider
Dec 16, 2005 10:12 PM
Hecdosage
Oct 28, 2005 04:48 AM
Edward
Jul 4, 2005 03:49 PM
