Front bumper beam??
I have that dreaded bumper sag going on with my 5th gen. It also looks like my front bumper might be a little off center. Can I just take my front bumper off and loosen up the bolts on the front bumper beam and move the front bumper beam over a little or is it in a fixed position. Also as far as the bumper sag goes. I replaced all of the clips for the bumper and it really didn't seem to help at all. Any other sugestions?? I have a jdm front end if that helps at all. Thank in advance.
as far as the ag you can either check if the upper bolts are loose for the bumper if they arent then you can take off the bumper cover and shim the bottom of the bumper with some washers. worked on my 4th gen. and i believe the side to side is in a fixed location and cant be moved.
BlueShadow
18
Apr 29, 2007 11:39 AM
gsrpedro
Feb 28, 2007 08:23 PM
