94 gsr 4door. 98 front end! NEW EVERYTHING! exedy. skunk2. fidanza. TENNESSEE
SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD SOLD
I originally bought this car as a project and due to work I am unable to find time to work on it. I am located in middle Tennessee
NO TRADES! I am now accepting $2500 obo because i am not selling the car without the skunk 2 suspension. IT WILL BE TOKICO STRUTS AND COILOVERS!
$3000 if you want it on Rota Auto x's instead of the Acura wheels.
-not bad considering i have $4400 invested in it.- $2850 worth of installed parts are listed below. this is not including that i replaced the tranny when i got it due to a grind. that was another $500.
1994 Acura Integra Sedan 4 door.
chassis miles: 280,xxx
motor miles: 71,xxx aprox.
transmission miles: 48,xxx
no a/c.
has power steering but needs a belt.
Exterior:
The exterior is basically the only part of the car that needs any work because i have already replaced close to everything else. There is some rust spots above the rear fender wells. It has your basic dings and dents here and there. It definitely needs a new coat of frost white.
-Amber corners $45
-1998 front bumper $120
-halo headlights $200
-true all red type r tail lights (took me quite a while to find these!) $250
Interior:
The interior is in ok shape. Nothing that I would be ashamed of but it does have its occasional burn mark. Its full gsr interior.
Suspension:
-tokico struts and coilovers
-skunk2 pro series front camber kit $190
-Ingalls style rear camber kit $50
Engine, tranny, and drivetrain:
-obd1 b18c1 gsr (hmotors swap) 71,xxx miles aprox.
-gsr transmission 48,xxx miles.
-Exedy stage one clutch and pressure plate. (brand new!) $260
-Fidanza 7.5lb flywheel (brand new!) $136
-Autozone axles (brand new!) $150
-bremo rear drilled and slotted rotors $100
-Autozone front rotors $50 JUST INSTALLED ON 8/14/07
-brand new rear calipers $145
-brand new pads front and back $45
-Sumitomo HTR 200 tires (brand new!) $250
-DC sport header $300
The bad:
The passenger side window needs a new switch because it has a short in it and stopped rolling down right after i bought the car.
The oil pan gasket is leaking but not enough to actually need to add oil but maybe once a month. I also do have the oil pan gasket to replace it and it will come with the car, I just haven't had time to put it on.
Ebrake doesn't work but should be an easy fix because it worked until i had the back brakes done at Gateway.
The GOOD:
Car pulls VERY strong. DOES NOT SMOKE A LICK ALL THE WAY TO 8,200 rpms!! Clutch grabs very nicely and transmission does not grind one bit.
I cannot think of anything else to list at this time but if i do i will update. Please bump if you view. My asking price once again is $2500 obo.
<br/>Shot with VPC-S500 at 2007-08-13
<br/>Shot with VPC-S500 at 2007-08-14
<br/>Shot with VPC-S500 at 2007-08-15 a little blurry but that is with the running lights on. rather sexy i think.
<br/>Shot with VPC-S500 at 2007-08-15 beautiful all red type r tails!!
<br/>
<br/>
<br/>Shot with VPC-S500 at 2007-08-19
<br/>Shot with VPC-S500 at 2007-08-19 brand new rubber
Modified by jonathan13 at 2:29 PM 8/19/2007
Modified by jonathan13 at 8:06 PM 8/19/2007
Modified by jonathan13 at 8:24 PM 8/19/2007
Modified by jonathan13 at 9:45 PM 8/19/2007
Modified by jonathan13 at 9:47 PM 8/19/2007
Modified by jonathan13 at 8:55 PM 8/21/2007
no a/c.
Exterior:
-Amber corners $45
Interior:
Suspension:
The bad:
The GOOD:
<br/>
<br/>
<br/>Shot with VPC-S500 at 2007-08-19 brand new rubberModified by jonathan13 at 2:29 PM 8/19/2007
back to the top. $3200 is an extremely fair price. ive got $4300 in the car right now so thats me losing $1100. i am open to trades as well but they need to have ac. thanks
up top again. the motor, tranny, clutch, flywheel, and suspension alone is worth $3200 easy!! come on guys its a deal and half
what i have this ek will u do a strait up trade?
btw. if u are interested i will make the drive to u for the switch. thanks
https://honda-tech.com/zerothread?id=2068559
before work and new pics bump. i have title in hand. had it printed today and ready for someone to sign it.. CLEAN TITLE!
ttt. new front rotors installed! this car is a steal! someone come pick it up or offer me a trade
