Question on runner length, homemade ITB'd LS/vtec
Old Aug 13, 2007 | 09:13 AM
89EF_Turbo's Avatar
Default Question on runner length, homemade ITB'd LS/vtec
I'm finishing up my ls/vtec bottom end atm, and I've been turning my attention to my homemade ITB project and wanted a little input as to runner length. I'm not shooting for a high-hp goal, it's just a low-budget build consisting of a stock block LS, stock pistons, and stock rods with ARP bolts and coupled to a mildly ported b16a head with a set of SiRII stock cams. The throttle bodies I have came off a 1300cc gsxr and thanks to Crome's new ITB utilities on the p30 rom base I'm going to use the stock gsxr tps sensor re-calibrated to the honda maps. Basically I'm getting ready to weld on the runners for the ITB's, and I'm trying to find what a good length would be to keep optimal bottom end torque but still maintain a good higher rpm curve. Anyone with some hands-on experience I'd appreciate the input, and thanks in advance!
Old Aug 13, 2007 | 01:21 PM
AccordSleeperZzZ's Avatar
Default Re: Question on runner length, homemade ITB'd LS/vtec (89EF_Turbo)
1st off - bump for a fellow DIY ITB builder.
2nd - i believe there's some math on calculating runner length for ITB's on this page, if i remember correctly. https://honda-tech.com/zero...age=2 if not, there's a bunch of otherwise useful information for ITB setups.
hope this helps dude.
Old Aug 14, 2007 | 12:25 AM
89EF_Turbo's Avatar
Default Re: Question on runner length, homemade ITB'd LS/vtec (AccordSleeperZzZ)
Thanks man, that link helps alot. After reading through that article and seeing how it affects low-end torque, I'm starting to wonder if ITB's are really the route I want to go.
uses0ap
Mar 16, 2009 10:30 PM
MPF_supra
Apr 13, 2008 09:59 PM
Mugencrxsir1
Feb 1, 2006 10:39 PM
crxsi8
Dec 9, 2005 04:08 PM
mrbsponge
Jan 6, 2004 12:11 PM
