95 gsr rebuild?
Old Jun 12, 2002 | 01:02 PM
swarsing's Avatar
Default 95 gsr rebuild?
i'm rebuilding the head and bottom end and want to use oem honda parts was wondering wich piston/ring combo and what valve train components to use this is my daily driver and want to use factory parts with whaat ever gains possible thanks
Old Jun 12, 2002 | 01:28 PM
GSpeedR's Avatar
Default Re: 95 gsr rebuild? (swarsing)
Would you like to retain the stock compression (I'm assuming not)?
I would suggest OEM rings with OEM pistons, the pistons depend on what you want. I would consider CTR pistons, but you may be happy with regular ITR pistons (USDM or JDM). I wish I could tell you exact C/R ratios, but I've only memorized the values for my block (B17a: which holds 11.4:1 to 10.8:1).
The valvetrain depends on what cams you want, so we'll need more input before we can give a suggestion.
Check the walls of your cylinder for wear markings, burn marks, etc. and you may want to re-bore/hone them accordingly.
Anyway, you have to be more specific, and people can help more efficiently.
Old Jun 12, 2002 | 01:37 PM
Tweakmeister's Avatar
Default Re: 95 gsr rebuild? (GSpeedR)
http://www.inlinefour.com
get some TypeR pistons
Old Jun 12, 2002 | 01:53 PM
Madness's Avatar
use usdm itr ~ 11:1 cr
ctr too high without tuning
itr/ctr cams, valve springs
r.f.b
Jun 7, 2007 12:25 AM
michielGSR
Apr 10, 2007 03:38 AM
psegs80
Oct 22, 2005 02:04 PM
93dx--hatch
Jul 2, 2005 05:51 PM
jeremy.
17
Oct 21, 2004 10:34 PM
