h22 and h23
Old Aug 13, 2007 | 05:51 AM
sr20cars's Avatar
Default h22 and h23
Guys, I am putting together an h23 block w/a 22 head. I am going to try and make an ITB setup using the 23 manifold. What i am asking is:
1. I believe the 22 and 23 run the same injectors, correct me if I am wrong??
2. Do I use a 22 headgasket or a 23??
3. This is going into an EG, does anyone know the axle combinations for this beast??
I am looking through past posts, but anyone with a second, and a bit o' knowledge, please let me know.
I am also looking for parts to make this happen, anyone with some leftovers, hit me up!!!
Old Aug 13, 2007 | 05:59 AM
alterdcreations's Avatar
Default Re: h22 and h23 (sr20cars)
2.3 manifold wont bolt up to the h22 head
head gasket is the same
they run different injectors. use the h22 ones
Old Aug 13, 2007 | 06:21 AM
sr20cars's Avatar
Default Re: h22 and h23 (alterdcreations)
nuff said, thanks for the input without the "dude your an idiot bs". Your a gentleman, and a scholar!
Old Aug 13, 2007 | 10:20 AM
giddyup21's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sr20cars &raquo;</TD></TR><TR><TD CLASS="quote">
1&2. There's plenty of write ups, search "h23 VTEC".
3. Depends on the mounts you're going to use, as well as the transmission you're going to use. Again all of this can be researched. Check the civic forum, and search for h2d or h2b.
Goodluck
Old Aug 13, 2007 | 11:46 AM
98vtec's Avatar
moderator emeritus
https://honda-tech.com/zerothread?id=510617
read the faq
hondamark35
Apr 6, 2009 12:34 PM
delslowh23
Oct 28, 2004 02:03 PM
JDMBB2
Jan 9, 2004 10:07 AM
