Wanted... LS Knowledge NA or TURBO
Old Aug 12, 2007 | 09:35 PM
TVietEBoyG's Avatar
Default Wanted... LS Knowledge NA or TURBO
i have an 98 ls teg, i wanna know wat do ppl mean by working on the engine head,... as in what do i have to do , and i am thinking of the NA route but seems like it would cost a lot of money and a lot of work must be done or just boosting the LS better? and how much would each cost? can someone give an est. plz what i want is a DD with just enough hp round 200-300 some kick but don't want to spend a lot of money
thnx again
Old Aug 12, 2007 | 09:48 PM
maniach4x's Avatar
Default Re: Wanted... LS Knowledge NA or TURBO (TVietEBoyG)
I have a 99ls teg, there are major parts to a engine, theres the Block that is the bottom end of a motor has your Crankshaft rods pistons etc, and your upperend called the head of the motor that has your cams camshafts valves valve springs retainers etc, these are just basic parts man, Now people with Ls' integra can go N/A or boost its all about what you like not how much it cost because u can spend the same amount on both setups, if your looking for 200plus hp u can do N/a but u need to know what your doing and tuning is going to cost u alot, boosting can easy get u 200plus but yet again its knowing what your doing and Nothing Is "cheap" do some searching and just don't post questions b/c all the 98% of facts are here.
Old Aug 12, 2007 | 10:52 PM
jdm_dc_fan's Avatar
From: "That one guy with that one car" Kennewick WA
the cheapest way to get 200-300hp would be turbo, but first you have a lot of learning to do.
knowledge is power.
Old Aug 12, 2007 | 10:55 PM
GSR in progress 96's Avatar
* B A N N E D *
With your goals your best bet would a turbo kit. It would be the cheapest and eaisest way to meet your goal.
Old Aug 12, 2007 | 11:49 PM
TVietEBoyG's Avatar
thn ppl, for the infor i'mma do more RESEARCH and thanks again
Old Aug 19, 2007 | 07:12 PM
red integra lsr's Avatar
you can only boost about 8lbs on a un sleeved block. if you build a turbo head for it you would be a little over 300hp. i built a lsv. if you do it right you can get about 220 to 250hp.
Old Aug 19, 2007 | 07:26 PM
Kyoto now's Avatar
Default Re: Wanted... LS Knowledge NA or TURBO (red integra lsr)
check the LS turbo thread in FI. Most people are making 250hp with 225 tq. on a stock motor. do some more research. LS Turbo+mild boost= more power and a lot more tq than than an LS VTEC for roughly the same price.
Old Aug 19, 2007 | 07:36 PM
GO-FIGHT-KILL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red integra lsr &raquo;</TD></TR><TR><TD CLASS="quote">you can only boost about 8lbs on a un sleeved block. if you build a turbo head for it you would be a little over 300hp. i built a lsv. if you do it right you can get about 220 to 250hp.</TD></TR></TABLE>
Maybe the biggest piece of misinformation I've ever read.
If you want 300whp, efficiently, and cost effective. Go with a nice turbo setup. All motor is rather expensive, and although it's fun, a mild all motor setup, is FAR more expensive than a mild turbo setup.
Do an LS/VTEC conversion, and boost that on 8-10psi with a decent sized turbo. If your engine is healthy, and your tune is good, you'll make good power (In the realm of 300whp), and you'll have all kinds of fun with it. 300whp doesn't sound like much, God knows Gran Turismo makes it seem like moped power, but 300whp in a lighweight Honda moves the hell out. With some good driving, you'd get some high 11s.
If you need to know what EXACTLY to do, and what EXACTLY to buy, just let me know, and I'll lay it out for ya'. I don't mind helping out a n00b, it'll make life easier on you.
Old Aug 19, 2007 | 07:49 PM
Kyoto now's Avatar
Default Re: Wanted... LS Knowledge NA or TURBO (GO-FIGHT-KILL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GO-FIGHT-KILL &raquo;</TD></TR><TR><TD CLASS="quote">
If you need to know what EXACTLY to do, and what EXACTLY to buy, just let me know, and I'll lay it out for ya'. I don't mind helping out a n00b, it'll make life easier on you. </TD></TR></TABLE>
what a sweetheart
Old Aug 19, 2007 | 08:08 PM
Haha, I wish someone would have helped me out when I was first getting into this years and years ago. So I don't mind helping out anyone who asks.
Team_Insane
Engine Management and Tuning
Mar 2, 2010 01:37 PM
matt97
Oct 13, 2009 07:14 PM
GoldCoin
Sep 6, 2007 11:27 AM
parfait2882
Feb 14, 2007 08:53 AM
96civich22
Aug 5, 2004 07:10 PM
