need help car wont go pass 7200
Old Aug 12, 2007 | 08:42 PM
badassmthr4000's Avatar
Default need help car wont go pass 7200
my car won't go passed 7200. for starters i got a gsr with a p28 chipped with hondata s300. i just had to replace the ignition control moduel or the inighter in the distributor. ever since then i can't go pass 7200. ive tried the type r program and still the same. anyone with the same problem or any help? thanks
Old Aug 13, 2007 | 04:27 AM
Dogginator's Avatar
Daisy... Daisy...
Default Re: need help car wont go pass 7200 (badassmthr4000)
Are you htiing a rev limiter or is the car losing power? If it is losing power, check the VTEC operation.
Old Aug 13, 2007 | 07:09 AM
Default Re: need help car wont go pass 7200 (Dogginator)
it sounds like i am hitting the rev limiter. on the program i maid sure that the rev limmiter is set at 8200
Old Aug 13, 2007 | 07:32 AM
Dogginator's Avatar
Daisy... Daisy...
Have you swapped the original ECU into the car to verify that the tach is working correctly?
Old Aug 13, 2007 | 08:18 AM
iH8RICERZ's Avatar
yeah, i'd also recommend trying out your stock ecu....if your stock ecu lets you rev past 7200 rpm, then you know its either the chipped p28 or the program your running that's causing the problem.
Old Aug 13, 2007 | 10:59 AM
dizzzane's Avatar
Default Re: need help car wont go pass 7200 (iH8RICERZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iH8RICERZ &raquo;</TD></TR><TR><TD CLASS="quote">if your stock ecu lets you rev past 7200 rpm, then you know its either the chipped p28 or the program your running that's causing the problem. </TD></TR></TABLE>
x2
Old Aug 13, 2007 | 08:35 PM
i don't have stock ecu. it was a ls before. i guess i can try to get one
Syndacate
14
Mar 13, 2020 01:59 PM
4d00rEF
11
Oct 23, 2009 01:10 AM
gsrpedro
Apr 23, 2008 06:31 PM
AkEuro_R
Apr 27, 2004 04:00 PM
