Auto P28 ecu to A Manual ecu
Does anyone have any pics or a how-to on changing a auto p28 ecu to manual p28 ecu i searched on how to but the link that everyone gave was no good. Any help would be great.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95sloweg »</TD></TR><TR><TD CLASS="quote">If i were you i would just invest in a maual p28.</TD></TR></TABLE>
No need to do that
I have that link somewhere where you just convert it over. I did it to mine when I did my auto to manual conversion. You remove 2 resistors and jump one of the resisters with a wire. BRB I'll look, unless someone posts b4 me
EDIT: Found the info from another post
Take a look at the following jumpers in the lower right hand corners of the ECU,
RP17 and RP18 values:
Auto to Manual:
remove RP17 and RP18
replace RP18 with a jumper wire
R18 shows a resistor but you use a wire.
No need to do that
Auto to Manual:
best idea cuz converting it the car still wont run like it would on a real manual one
