D15B7 cam?
Old Aug 12, 2007 | 06:09 PM
Missouri_Civ's Avatar
Default D15B7 cam?
Does anyone know of a company that makes performance cams for D15B7 engines? I realize the market is probably pretty limited on using these engines for performance purposes, but I figured it was worth asking.
Also, I'm not particularly familiar with the effects of upgraded cams outside of the hot rod world. Do they produce the same "pop-pop" idle effect on Civics as they do on Chevy small blocks?
Thanks to all who answer.
Old Aug 13, 2007 | 02:11 AM
Mista Bone's Avatar
D Tranny Guru
http://www.d-series.org/forums...22640
There is also a thread on here.
You can use a D16A6 cam, but must correct of the 5mm shorter D15 deck height by using a 96-00 Y7/Y8 cam gear.
Crane 251-0016 will "pop" and idle like crap for the overlap and LSA.
ITSTOCK
Nov 24, 2003 01:21 PM
pornstarSR
Oct 11, 2002 02:55 PM
J T*
Jul 23, 2002 09:46 PM
