who got z10's what you think of em
Old Jun 12, 2002 | 11:24 AM
PM-Performance's Avatar
Default who got z10's what you think of em
im thinking of getting a set, how do they help for wheel hop? easy to mess with? i got a stock susp so far. but have crazy wheel hop all the time
Old Jun 12, 2002 | 11:25 AM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: who got z10's what you think of em (itr206)
Buttcoin just installed them right before expo. Forgot to ax him what he thought of them
Old Jun 12, 2002 | 11:26 AM
sackdz's Avatar
Default Re: who got z10's what you think of em (Splat)
They are kickass. Wheel hop virtually non existant
Old Jun 12, 2002 | 11:38 AM
Default Re: who got z10's what you think of em (sackdz)
so you think i an still gain even though my susp is still stokc for the moment
any probs on the install? probs with adjusting ?
Old Jun 12, 2002 | 11:39 AM
DC2-8888's Avatar
do u guys have a link for that and how much is that
Old Jun 12, 2002 | 11:45 AM
sackdz's Avatar
Default Re: who got z10's what you think of em (DC2-8888)
Yep I originally installed mine with stock suspension.
The installation of the main cross bar was a little tricky. It goes across the front right under the radiator, and mounts to the holes where the tow hooks gp (tow hooks will be removed). It's a tight fit and somewhat difficult to line all the holes up, but once you get one in loosely on each side it's better. I used a jack to help push the bar up into place. Unfortunately I was a little overzealous, and cross threaded the frame hole when installing one of the bolts. One day (probably never) I will go and retap it and put in the last bolt (I'm using 3/4 now). But the way the flanges sit, the bolts just hold the bar in place anyways, and don't do any work really, so it's all good.
I used 2 or 3 complete turns of preload (make bar shorter, pull LCA toward front) on each side. I did it while getting an alignment, and the camber/caster/toe numbers didn't change at all.
hth
Old Jun 12, 2002 | 11:47 AM
-Gambit-'s Avatar
i have them on my 98 hatch, I love them no wheel hop at all.
sackdz's Avatar
hth
Z-10 Engineering is a honda-tech sponsor, look for their banner at the top of the page, or click here
I bought my bars through the intial group buy last year for around $340 or so.
[Modified by sackdz, 3:50 PM 6/12/2002]
Old Jun 12, 2002 | 12:06 PM
they are 389 there. unless you gotta call them and say your with ht? and they give you a discount?
b18bturbo is selling thme for 356 shipped right now . thats where i was gonna get em from .
Old Jun 12, 2002 | 12:12 PM
nEoMuGen's Avatar
How low is that thing? Will it bottom out?
Old Jun 12, 2002 | 12:14 PM
Default Re: who got z10's what you think of em (nEoMuGen)
from what i heard no unless you are really really really low.
Old Jun 12, 2002 | 02:59 PM
EagleR's Avatar
How do they effect handleing, will the car turn in better? Does it help get power down comin out of the corner. I know the drag benefits....but i was wonderin for road course/ auto-x / spirited street drivin Etc...
Old Jun 12, 2002 | 03:05 PM
-Gambit-'s Avatar
Default Re: who got z10's what you think of em (EagleR)
handling wise it will help you pull out of corning, but it wont hurt your corning speed at all, you wont lose any turning radius, there will be no ill effects from z10 radius arms
Old Jun 13, 2002 | 01:29 AM
Eeepers's Avatar
New User
If you don't scrape your toe hooks then u will be just fine.
Old Jun 13, 2002 | 02:32 AM
sackdz's Avatar
Well the lowest point is higher than the bottom of the LCA, so unless you're scraping those you should be okay
Old Jun 13, 2002 | 07:36 AM
well i just ordered from Viren for 356 shipped .
Old Jun 13, 2002 | 07:45 AM
sackdz's Avatar
Enjoy!
Old Jun 13, 2002 | 12:07 PM
thanks for the help.
Old Jun 13, 2002 | 09:53 PM
Incognito's Avatar
They work if they're set up right.
You probably know that i've done my fair share of drag racing.
Until you have them set nearly perfect, you're still going to get wheel hop.
I was having axle breaking problems, and these seemed to help out a bit.
I still get wheel hop, but not as violent as stock.
Invest in some motor mount inserts also.
Old Jun 14, 2002 | 04:17 PM
Lip's Avatar
Lip
Default Re: who got z10's what you think of em (Incognito)
your the only one getting that wheel hop. i swear you got issues with that suspension
Old Jun 14, 2002 | 04:33 PM
sackdz's Avatar
I correct myself, the front brackets hang lower, but not as far as the header.
sack-who just saw he dented the **** out of his header, has a bent rear tie bar, and has no clue how it happened
The Weather Man
Jan 22, 2006 10:07 PM
ghostsi69
Suspension & Brakes
13
Dec 3, 2005 12:58 PM
W O T
33
Oct 31, 2005 05:34 PM
playboyace35
Feb 18, 2005 03:01 PM
eg6ajk
Mar 6, 2002 05:09 PM
