b16a seized? Hydrolocked? Help?
Old Aug 12, 2007 | 02:34 PM
denraweb's Avatar
Default b16a seized? Hydrolocked? Help?
Ok, so I have a B16a obd-0. I bought a CRX Si, with this motor in it already. I believe it needs a new harness, that's why I bought it, easy fix (with the added wires for the b16 of course) I finally re-did some wiring and got the engine to crank. Just as it was about to turn over (or it sounded like), "CLUNK!", the engine stopped cranking. I tried to manually crank the engine, but after a certain point, not even turning the crank one full turn, it would be impossible. I was using a torque wrench too. I had my fiancee try to start it as I jiggled the crank a little. The crank was turning, but very very slowly, so it was not completely stopped, it was actually spinning. She did that a couple of times, then as I was gonna call it quits on cranking it, gas start pouring out of the exhaust, just where the header meets the cat flange. I had her stop, and after that, I did not have it cranked since then. I pulled the oil dipstick from the block, and gave it a big whiff...what did I smell gas...which is normal, but not overwhelming. So does this mean the engine is hydrolocked 'cuz of the gas flooding the engine??? Or is it just seized...also I may have a hunch that it could be a tranny problem, 'cuz I put the car in neutral, and I can't move it, as if it's in gear...anyone have any idea? Would it help if I do the "fix the hydrolocked engine" thing, with a wet vacuum through the spark plug holes?
Motor has around 35,000 miles.
HELP!!!!
Thanks in advance for any info guys.
Old Aug 12, 2007 | 02:47 PM
Suck my DX's Avatar
Default Re: b16a seized? Hydrolocked? Help? (denraweb)
remove the spark plugs...disconnect the dizzy ....and crank out the excess fluid...cross you rfingers and hope you didnt break/bend anything by cranking it while locked
Old Aug 12, 2007 | 03:34 PM
CRX Toad's Avatar
Default Re: b16a seized? Hydrolocked? Help? (Suck my DX)
You can also try to use a shop vac if you are uncomfortable with the above that Suck my DX said. I used a shop vac to suck out all the diesel and oil out of my truck when I put my bigger injectors is worked like a charm.
Old Aug 12, 2007 | 10:02 PM
denraweb's Avatar
Default Re: b16a seized? Hydrolocked? Help? (CRX Toad)
Are all shop vacs dry/wet? Or should I keep my eyes open? Never really paid attention to shop vac labels...
Old Aug 12, 2007 | 10:04 PM
denraweb's Avatar
Forgot to mention, I got it cranking correctly...but I'm throwing a code 16 on the pr3, and my injectors are working (used stethoscope to verify), and I know my fuel pump is working 'cuz I can smell the gas when I crank it. So my next option is to change out the resistor box...anyone know if you can test them?
masterbuilder
Aug 7, 2007 07:14 AM
88whitehf
Dec 24, 2002 10:14 PM
