h22 swap...
Old Aug 12, 2007 | 02:28 PM
motoxx644's Avatar
Default h22 swap...
just bought a h22.. are the H series valve clearences dif. from the b series? should be 6 and 8 correct?
Old Aug 12, 2007 | 05:05 PM
motoxx644's Avatar
Default Re: h22 swap... (motoxx644)
bump
Old Aug 12, 2007 | 05:20 PM
trrbl1bmx's Avatar
Assuming you have stock cams in. .006''-.007'' intake cam, and .007''-.008'' on exhaust. Make sure when you do these adjustments your engine is COLD like sitting over night cold.
Old Aug 12, 2007 | 06:32 PM
motoxx644's Avatar
Default Re: (p00n)
yes.. also the lobes above each piston MUST BE pointng up before you check the lash, but thanks for the clearence numbers
88h22_CRX
Mar 5, 2013 01:31 PM
Ethan2536
Dec 9, 2010 08:45 PM
six_speed
Mar 9, 2010 06:34 AM
Acura_DreamiN
May 12, 2009 07:01 PM
burplelude
Jun 9, 2006 10:40 AM
