Main relay location????
Old Aug 12, 2007 | 12:38 PM
si_motor_spt's Avatar
Default Main relay location????
Does any one know where the main relay is in a 2000 civic ex 2 door? maybe some pics if possible....Thanks..
Old Aug 12, 2007 | 01:33 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: Main relay location???? (si_motor_spt)
Check this link out:
http://techauto.awardspace.com/civicrelay.html
Old Aug 12, 2007 | 01:36 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatGuy4life &raquo;</TD></TR><TR><TD CLASS="quote">For future references:
To get to main relay on 2000 civic si, you need to reomve the panel on the far right side of the dash
then drop you glove box look inside where the glove box was to the right and you will see the main relay (don't mind all the wires you see in my pics, those are to the relays for my door poppers so yours won't look exactly like mine)
you can also see it from outside
It's being held by a 10mm bolt
remove the bolt remove the relay from the bracket and remove the connector, install in reverse.</TD></TR></TABLE>
Old Aug 13, 2007 | 09:27 AM
Default Re: Main relay location???? (BlueIntegraBoy)
Thanks for the help, i found it right where you said it would be...
trav143
Oct 8, 2008 09:01 PM
stevescivic
May 11, 2007 12:50 AM
EKHWhat
Mar 17, 2007 11:41 AM
ThatGuy4life
Feb 5, 2007 08:53 AM
SwiftTypeR
Nov 14, 2004 03:58 PM
