lsvtec compression ?
Old Aug 12, 2007 | 12:17 PM
123Four's Avatar
Default lsvtec compression ?
JDM GSR head on B18B block
P30 pistons = ?
P72 gsr pistons = ?
P73 usdm pistons= ?
What are the compression ratio using standard size pistons? Thanks.
Old Aug 12, 2007 | 04:18 PM
123Four's Avatar
Default Re: lsvtec compression ? (123Four)
i know someones gotta know... help me out guys.
Old Aug 12, 2007 | 06:59 PM
doood's Avatar
been there done that
http://www.c-speedracing.com/h...c.php
not the most accurate but it'll give you a close idea
Old Aug 12, 2007 | 09:24 PM
Ryank327's Avatar
Default Re: lsvtec compression ? (doood)
That sites telling me Id have a higher compression running Pr3s over p73s is this correct?
Old Aug 14, 2007 | 04:27 AM
123Four's Avatar
Default Re: lsvtec compression ? (Ryank327)
so do we estimate up or down on the result on that calculator?
Old Aug 14, 2007 | 07:01 AM
Jay_Sensing's Avatar
Yes you will have higher compression running B16 pistons over ITR pistons.
The estimation can be higher or lower. The only way to know for sure is measure your piston to deck height and cc your combustion chambers.
VVENOM800TT
Feb 17, 2011 02:48 PM
Vpenh
Jul 30, 2006 12:26 PM
b18cthashit
May 17, 2003 09:22 AM
jetdriven
May 6, 2002 06:44 AM
