Idle Air Control Valve
Old Aug 12, 2007 | 12:06 PM
H22Luda720's Avatar
Default Idle Air Control Valve
I have a 94 Prelude, h22a1, just got done building it, i need another idle air control valve but am having trouble finding an application specific valve, long story short what IACV's are interchangable with 94 h22a1, thanks
Also, it is being mounted on a custom made intake mani. so bolt/port location is not an issue, as long as the connector and operation is the same
Old Aug 12, 2007 | 01:06 PM
H22Luda720's Avatar
Default Re: Idle Air Control Valve (H22Luda720)
bump
Old Aug 12, 2007 | 02:18 PM
2point2's Avatar
any two wire honda iac will plug right in to the clip.
Old Aug 12, 2007 | 04:46 PM
InvaderTrax's Avatar
Doesn't mean it will bolt to the manifold...
Old Aug 12, 2007 | 05:49 PM
H22Luda720's Avatar
Default Re: (InvaderTrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">Doesn't mean it will bolt to the manifold...</TD></TR></TABLE>
Doesnt matter, custom fabd manifold,
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2point2 &raquo;</TD></TR><TR><TD CLASS="quote">any two wire honda iac will plug right in to the clip.</TD></TR></TABLE>
thanks
Old Aug 12, 2007 | 05:54 PM
mgags7's Avatar
you should be sure that the IACVs from other hondas will interface correctly with your ecu. I believe the b16 one will work fine, why not just buy a prelude one and make it work?
Old Aug 12, 2007 | 06:02 PM
H22Luda720's Avatar
Default Re: (mgags7)
i was worried about that also, up until about five minutes ago i was having trouble finding one, got a hit in wtb post, thanks anyways
H22Luda720
Aug 14, 2007 10:25 AM
Francesco
Honda S2000
Dec 5, 2006 11:37 AM
SupraRXZ
Jan 23, 2006 04:31 PM
E-spec Tuner
Jun 10, 2005 11:46 PM
Armed Ferret
Dec 22, 2004 11:19 PM
