f*cked suspension
Old Jun 12, 2002 | 11:11 AM
Martaigne's Avatar
Default f*cked suspension
So I just got back from the alignment shop... apparently my lovely northeastern rusted-out pos is SO rusted out half the bolts used to align the car are completely frozen.
I get to replace a rear lower control arm, and the guy suggests I replace my entire steering rack. How hard is the rack to replace, if I manage to get one at the junkyard?
Old Jun 12, 2002 | 11:13 AM
SOHCArchangel's Avatar
Default Re: f*cked suspension (martaigne)
wtf, the ENTIRE??? steering rack?
Old Jun 12, 2002 | 11:34 AM
greensleeper's Avatar
I'd get under there and check it out yourself... sounds fishy... if you do have to replace the entire steering rack take one out of a prelude - it has a better steering ratio nd will bolt right up... supposedly...
Old Jun 12, 2002 | 12:58 PM
Martaigne's Avatar
Default Re: f*cked suspension (greensleeper)
It's the part that the tie rods attach to... in short, the tie rods are fucked, and I just picked up the um.. I guess it's just the pinion(?) from the junkyard for $100
The guy working on the car would in no way profit from me repairing it, it was just an alignment/tire shop. He showed me exactly what the problems are... I don't think your tie rods are supposed to be able to be liberally shaken back and forth, that causes play in the steering wheel, which I had since I curbed my car avoiding an accident.
I got to pick the car it came from, it was an Accord with no front end damage. I've got what I need, but how hard will this bitch be to put in without a lift? Or should I have a professional do it?
Old Jun 12, 2002 | 01:10 PM
Martaigne's Avatar
Kinda funny, when you think about it... I curbed my car avoiding an accident and it caused me a good $2000 worth of damage in the long run... from suspension and steering damage to eventually hydrolocking and blowing up my engine because the fender lining was torn off.
I shoulda nailed the ******.
Old Jun 12, 2002 | 07:25 PM
TypeSH's Avatar
hmm... where did you hear this from? I'd like more info on whether or not you can bolt them up...
Old Jun 12, 2002 | 10:01 PM
Martaigne's Avatar
Default Re: f*cked suspension (TypeSH)
Heh... that last word... 'supposedly'. That's enough to deter me for the moment.
Old Jun 13, 2002 | 05:47 AM
Martaigne's Avatar
Good god... I just got off the phone with Mahdavi Motorsports... it IS the ENTIRE rack that I'd be replacing, they also recommend it, but it's a 4-4.5 hour job, plus an alignment, that equated to $400 for the alignment and labor.
Now I'm starting to consider throwing the car up on jack stands and doing it myself. I managed an engine swap, a steering rack shouldn't be that hard, right?
Just wish I had a lift...
Old Jun 13, 2002 | 09:47 AM
A friend of mine from HART told me it was possible... I really haven't looked into it to much. Those guys know some crazy ****... especially about switching parts from one model to another (probably because most of them hand a hand in designing it!)
Old Jun 13, 2002 | 05:10 PM
Brandon's Avatar
Life is Suffering
I suggest that you try to unfreeze the bolts with some PB Blaster before you get a new control arm.
Old Jun 14, 2002 | 07:07 AM
Martaigne's Avatar
Default Re: f*cked suspension (vtec2k2)
I'm going to have to unfreeze them anyway, but I'm going to replace it no matter what... my bolt looks like a blob of rust. The steering rack I have to replace because of damage and wear, too.
Registered user
Nov 17, 2016 05:02 AM
JJ291
Honda Civic (2001 - 2005)
Jul 26, 2013 05:28 AM
91GEDHATCH
11
Dec 19, 2010 11:52 AM
furiousbob
Mar 13, 2009 02:26 AM
EZ$$EF
Jan 7, 2008 04:07 PM
