1991 std. rear disc swap
I SEARCHED FOR 2 HOURS in the archives and current post section. Give me a break!!!!!!
I have a 91 std. I just got all of the rear disc brake assembly from a 90 Integra. My question is can i just swap the whole control arms or do i have to mix and match parts across from each other.
We will be taking extensive pictures to help those who can't find a good guide as to what things need to be swapped
just change out the actual trailing arms while leaving the EF upper and lower control arms attached to the car and a BIG thing to remember is to leave the front tow adjustment arms alone where they attach to the body, just dissconnect the arm at the trailing arm instead of the frame so you won't throw the alignment off nearly as bad (though still get an alignment after install). I am suprised you have not found this info after looking for that long cause I know I have seen it on here more than a few times?? oh well, search does not always work right. you can pm me if you have any other questions on this
https://honda-tech.com/zerothread/1508680
http://crf50.no-ip.com/fourthg....html
If you would have just looked in the FAQ your question would have been answered in 2 minutes.
specialized108
21
Nov 7, 2008 04:44 PM
Xemu
Feb 3, 2008 09:36 PM
