bent valve question
Old Aug 12, 2007 | 07:37 AM
simply's Avatar
Default bent valve question
Recently my car has been consuming a lot of fuel. The only thing I can think of that might be a problem with my motor is a bent valve. Would having a bent valve result in to much fuel consumption?
Old Aug 12, 2007 | 05:28 PM
NJIN BUILDR's Avatar
Default Re: bent valve question (simply)
It could but it's not likely your problem.A compression test will tell you if it's a bent valve.It's more likely a bad o2 sensor or injector.
kornkid21792
Mar 3, 2010 01:06 PM
JBBNJ609
Dec 13, 2003 10:56 AM
nY's FiNeSt
Jul 7, 2003 09:07 AM
GreenD
Apr 25, 2002 07:30 AM
