oh how much i hate my ef right now.
Old Aug 12, 2007 | 06:10 AM
tougetuned_ef's Avatar
Default oh how much i hate my ef right now.
So i was on my way to honda day yesterday, and all of a sudden my b16 starts cutting out and pullin back on me. i pulled over and shut it off for a couple of mins. i started it back up and it ran fine for the rest of the ride there. but on the way home, i went through one toll and had to slow down to wait for a friend and the car just suddenly stalled on me out of no where. started it up again and started back on the highway. about 25 mile from my house on the pa turn pike my car throws a cel and just starts shutting down then coming back on the shutting down then coming back on. had to get it towed to a friends house.
im going to try this new dizzy i got and see if that fixes it. oh yeah it also turns out ive had ls plug wires on my car for 2 years and they are a half an inch to short
any input would be appreciated
Old Aug 12, 2007 | 09:57 AM
reydio's Avatar
Default Re: oh how much i hate my ef right now. (tougetuned_ef)
Also check your main relay, could be one of the culprit.
Old Aug 12, 2007 | 10:20 AM
VtecSyndrome's Avatar
I've seen bad coils do this too (like on my B16 rex) so if replacing the dizzy make sure your also replacing the coil. What code did the CEL spit out?? find that out before just throwing a new dizzy at it, it will SUCK to spend that money for nothing. have you pulled your dizzy cap off yet? make sure the rotor button screw did not vibrate out cause it will also cause this, at least visually check everything out before spending money blindly
Old Aug 12, 2007 | 10:36 AM
89s1's Avatar
Default Re: oh how much i hate my ef right now. (VtecSyndrome)
its the plug wires.
its gotta be.
Old Aug 12, 2007 | 10:50 AM
Default Re: oh how much i hate my ef right now. (89s1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89s1 &raquo;</TD></TR><TR><TD CLASS="quote">its the plug wires.
its gotta be.</TD></TR></TABLE>
they have been on for 2 years working fine and now you think it's GOTTA be the wires?? very unlikely, I still rec. the correct wires but I really doubt thats what caused this
Old Aug 12, 2007 | 12:06 PM
jayturboef's Avatar
ive seen the screw on the rotor inside the dizzy cap come loose and cause this type of problem....check that and get back
Old Aug 12, 2007 | 12:37 PM
SIred91's Avatar
Rainman
Default Re: oh how much i hate my ef right now. (jayturboef)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayturboef &raquo;</TD></TR><TR><TD CLASS="quote">ive seen the screw on the rotor inside the dizzy cap come loose and cause this type of problem....check that and get back </TD></TR></TABLE>
x2........
Old Aug 12, 2007 | 12:45 PM
89s1's Avatar
he said in another thread that the plug wires he borrowed form a friend cleared it right up.
Old Aug 12, 2007 | 02:02 PM
EFHATCHMAN's Avatar
I would also agree with JayturboEF and SiRed91... this has happened to me about three times in the last two years... check it out and let us know
Old Aug 12, 2007 | 03:06 PM
Default Re: oh how much i hate my ef right now. (EFHATCHMAN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EFHATCHMAN &raquo;</TD></TR><TR><TD CLASS="quote">I would also agree with JayturboEF and SiRed91... this has happened to me about three times in the last two years... check it out and let us know </TD></TR></TABLE>
yep, like I mentioned above <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">make sure the rotor button screw did not vibrate out cause it will also cause this</TD></TR></TABLE> this is common, happend to me a couple times until I finally wised up and used locktite (blue kind) when I reinstalled it and it has not come out since other than the few times I replaced my rotor button.
I hope it is something this simple, nothing better than a problem turning into a free fix
Old Aug 12, 2007 | 05:18 PM
2slow4stock's Avatar
yeah, screw for the rotor... happened to me x5 million. but screw it JB weld it in! never have to worry about it falling off!!!
Old Aug 12, 2007 | 06:21 PM
curioso's Avatar
hmm sounds like what mine had it was my ignition starter switch under the steering wheel that fixed my problem and it sounds the same also it would do the same thing act up and run fine again.... try it out...
Old Aug 13, 2007 | 02:56 PM
i just put brand new vtec wires on! i had a brand new dizzy in the car but no 12mm open end. i will put the new dizzy on weds when i get it back and let you know how it goes. i didnt get the code cause i didnt have a jumper on me and i have obd1 so no light on the ecu.
Old Aug 13, 2007 | 02:58 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89s1 &raquo;</TD></TR><TR><TD CLASS="quote">he said in another thread that the plug wires he borrowed form a friend cleared it right up.</TD></TR></TABLE> the wires cleared up the hesitaion for about 2 hours then it came back. i think it was just a fluke
Old Aug 13, 2007 | 03:33 PM
rayzian's Avatar
I feel ya, one time my car stalled, wouldn't want to start.. was getting CELs and everything, would just keep cranking.. 2 minutes later a tow truck stopped by... he charged me $60 to tow it back home (which was literally 2 blocks away) and when I got home, I reset the hazard fuse and low and behold, the car started up fine...
Two or three weeks ago, on the highway, somehow.. my passenger fender liner ripped off and took my mudflap with it.. it also somehow managed to damage my passenger corner light ripping it out of the socket..... So many times I've thought about giving up on my EF, I just take a look at the rust that I can't afford to fix and my mind just tells me to get another car.. but I won't give up on her
Old Aug 13, 2007 | 03:44 PM
SIred91's Avatar
Rainman
Default Re: oh how much i hate my ef right now. (rayzian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tougetuned_ef &raquo;</TD></TR><TR><TD CLASS="quote"> the wires cleared up the hesitaion for about 2 hours then it came back. i think it was just a fluke</TD></TR></TABLE>
Positive battery cable.
Old Aug 14, 2007 | 01:40 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rayzian &raquo;</TD></TR><TR><TD CLASS="quote">
Two or three weeks ago, on the highway, somehow.. my passenger fender liner ripped off and took my mudflap with it.. it also somehow managed to damage my passenger corner light ripping it out of the socket..... So many times I've thought about giving up on my EF, I just take a look at the rust that I can't afford to fix and my mind just tells me to get another car.. but I won't give up on her</TD></TR></TABLE>
i just bought an 01' crv last night and i think im done f*cking around with old hondas for now. i'm just gonna get it running good and sell it. gonna save some money till i can afford something in nice condition. when i bought itoff my friend, it was gutted already and the d motor didnt run. ive had nothing but problems ever since. when the b series was in my da it ran like a champ!
It needs someone who really know what they are doin when it comes to fine tuning an ef with a b series in it. but im sure when i get it running again i will change my mind and wanna keep it like i always do.
Old Aug 15, 2007 | 12:00 AM
When its running, put the CRV bottem end in it!!!! wo0t.
Old Aug 16, 2007 | 08:42 AM
Default Re: (2slow4stock)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2slow4stock &raquo;</TD></TR><TR><TD CLASS="quote">When its running, put the CRV bottem end in it!!!! wo0t.</TD></TR></TABLE>
my mom co-signed on the loan for me and she said if i touch the crv shes gonna rip my arms off!!!! well i just got the car back to my shop and im wiating for the head mech to get time to look at it and i will def post my results!
Old Aug 16, 2007 | 08:45 AM
ProSlow07's Avatar
Lemme know what the deal is because when I drove my car on leave mine did the same time only in a faster span of time. I just said screw it and swap it since it's the HF engine but I would like to inform myself just incase it happens again.
BTW I replaced the dizzy and plugs & wires and it kept doing it..
Old Aug 16, 2007 | 09:15 AM
mike-y's Avatar
Default Re: (tougetuned_ef)
hope it works out for ya. Just so you know, those CRVs are notorious for failing AC compressors :-P
Old Aug 17, 2007 | 05:08 PM
Default Re: (mike-y)
well i still havnt got into the car yet. tomarrow morning when i get done work me and my boss are going to start looking into it. ive been so busy i havnt got to look at anything.
and as for the ac comp, its no different than any other b series ac comp. so if they are notorious for it than so would ls integras and em1 si's. unless your talking about a k series crv than i wouldnt know. i dont know **** about k series. nor do i care about them cause i could never afford one. and i work at a shop now so i could easily change it if it did go bad. i barely use it anyway. i just open all the windows. im just glad i have a regular whip that i dont have to worry about it breaking down on me. im deffinatly not putting any money into this thing!!!!!
Old Aug 21, 2007 | 03:14 PM
ok so i put my old dizzy back on and the car started right up like nothing ever happened. ran good but i havent had a chance to dive it around long enough to see if the hesitation is gone. im thinking of replacing the feul filter to see if it might be clogged up.
Old Aug 21, 2007 | 03:59 PM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
I have no idea why, but when I read that I busted out laughing.
I'll buy your 89 si as it sits, you don't even have to fix it!
Old Aug 23, 2007 | 03:30 PM
Default Re: (ComeOnKip)
its running. turns out there was a tiny pin size hole int the dizzy cap. it was arching off my test light. so i put a new cap on it. but it still stalls out on its own. the mech i work with thinks its a problem in this shitty jhpusa conversion harness. i will sell the car for $3000 or best offer. look in my sig for details.
Modified by tougetuned_ef at 5:36 PM 8/23/2007
trippsEF9
Dec 31, 2012 09:16 AM
kilassapsap
May 23, 2011 05:23 PM
Trung Nguyen
13
Feb 24, 2010 03:18 AM
niccer
Jul 22, 2009 04:18 AM
