Type R Cams Type R Intake Manifold ?
i have a 2005 rsx type s, i want want to put in Type R Cams Type R Intake Manifold. is that a good ideal or not, will that make a different or not in hp ?
the cams you have pretty much are type-R cams and if you want a good intake manifold you should go with an RBC intake manifold off of the 2006 civic Si i think it flows like 30% better than the type R manifold
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc5RickK20 »</TD></TR><TR><TD CLASS="quote">the cams you have pretty much are type-R cams and if you want a good intake manifold you should go with an RBC intake manifold off of the 2006 civic Si i think it flows like 30% better than the type R manifold</TD></TR></TABLE>
unless you want to go with the new civic type-r intake manifold. i believe that it is a re-worked rbc-like manifold. im not sure where the hell you can get one yet though
you would gain some power but not as much as some of the others listed above which may be a little cheaper on the price ... not sure though so its up to you
