Heagasket question 85x92mm p2v problems.!
my valves and pistons are hittin each other
block has wiesco endyne piston 14.1cr
and the head is gsr head wit pro3s
using a 85mm .030 head gasket
my question is can i stack 2 stock gaskets and get away wit it. my head is milled possible .020 to .030. by stacking 2 it would be as i my head wasnt milled at all.
wat you guys think?
Modified by AllMotor12s at 11:40 AM 8/12/2007
wat you guys think?
i cant afford to take everything apart and re buildeverything. if i was gunna do that i would jus get another head that hasnt been milled
Did you degree in the pro 3's? if not you will have that problem.. We had to advance the ex cam 6-7 degree's on the gear.I have 10cc domes and no p to v issues.
hmm well i degreed the exhaust to 5 and intake the to 1. still u can feel when i spin the crank its hit the valve a lil bit. also this is with the valve lash all the way out...
Cometic makes custom gaskets all the way to .074.
Also Inlinepro.com (or something like that) makes 2 mm and 3mm head gaskets.
and...you can't wait for 2-3 weeks?? This is what happens when you put abig *** fucken cam in, with big *** fucken pistons... my suggestion wait, to be safe? or get some pro2's instead of pro3's.
This website has a large selection of HGs, may have something instock you can use.
http://www.raceeng.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotor12s »</TD></TR><TR><TD CLASS="quote">race engineering has the one i need in stock im bout to order it now .</TD></TR></TABLE>
How the hell do you know that? Id bet my left nut you didn't measure anything, who degreed your cams? If your able to degree cams properly why cant you measure piston to valve clearances?
Any idea what your valve to valve clearances are? Didn't think....
Leave the engine building to the guys who have a clue. It blows my mind why someone can drop the amount of money you have in a motor like yours their first time and expect it to be correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Natural Aspirations »</TD></TR><TR><TD CLASS="quote">
Leave the engine building to the guys who have a clue. It blows my mind why someone can drop the amount of money you have in a motor like yours their first time and expect it to be correct.</TD></TR></TABLE>
ROFL
ROFL
if your pistons are hitting your valves just by turning the motor over chances are you bent a valve doing this. better take the head off and check all the valves for straightness. id advice advancing the ex cam 1 more degree. 4 degrees seperation isnt enough on pro 3s
first of all you dont kno me so expletive you. my motor is fine. for those of you who think i bent the valves. the valves are straight as a arrow.
i love e-thugs you think your tuff behind a screen suck a dick come too my face and say sumthing.
you guys are so ****** cool
for anyone else the head is milled 30 thousandths i already know theres gunna be a clearence issue. hence why my title says headgasket question.
also i didnt mention i had already bolted down a b16 head which was never milled and everythign clears fine......
As recommended before, you can keep the headgasket you are using now, and advance the exhaust cam another couple degrees. The more advanced the exhaust cam, the sooner the valve closes in relation the the incoming piston = more P2V.
FWIW I have my Pro3's at +2/+5, installed on recommended Skunk2 centerlines (100/104).
To clear things up, when you say you degreed the cams in, did you use a degree wheel on the crank and dial fixtures to install the cams on the correct centerlines? or did you just install them at "TDC" and adjust the gears?
I have to add though, having P2V on the primaries, I would assume something isn't right. I've seen 8 degrees of clearance on BC5's with +11cc domes, and they have even more low-lift duration than Pro3's.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotor12s »</TD></TR><TR><TD CLASS="quote">also i didnt mention i had already bolted down a b16 head which was never milled and everythign clears fine......</TD></TR></TABLE>
thats some pretty important info there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AllMotor12s »</TD></TR><TR><TD CLASS="quote">bout to jus boost this ****</TD></TR></TABLE>
doooooo iiiiiiit
doooooo iiiiiiit
Please do
Please do
