Girdle for LSVTEC
Old Aug 11, 2007 | 01:55 PM
7rrivera7's Avatar
Default Girdle for LSVTEC
I want to get either a KMS or Endyn girdle for my LSV build and I know I need a GSR/Type R crank cover, oil pickup, windage tray and main cap bolts.
My question is do I need the GSR/Type R main caps or just the screws to use with my B18 main caps? Are the B18 and GSR/Type R main cap screws the same lenght?
Any opinions on the KMS girdle which is cheaper than the Endyn unit?
Old Aug 11, 2007 | 02:08 PM
pasaunde's Avatar
I just put a GSR girdle on a B20, the parts I used are:
GSR
Oil Pan
Oil pickup
windage tray
2,3,4 main bolts, the Ls ones are to short
Machined #3 Ls main
Machined GSR Girdle
If your going with aftermarket I would ask them about the installation specifics, they should be able to tell you.
good luck
Old Aug 11, 2007 | 02:12 PM
DonF's Avatar
Default Re: (pasaunde)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pasaunde &raquo;</TD></TR><TR><TD CLASS="quote">I just put a GSR girdle on a B20, the parts I used are:
GSR
Oil Pan
Oil pickup
windage tray
Machined #3 Ls main
Machined GSR Girdle
good luck </TD></TR></TABLE> How hard was it to machine the 3 LS caps for the dowel pins that tie all this together and make it work?
Old Aug 11, 2007 | 02:37 PM
7rrivera7's Avatar
Default Re: (DonF)
Bump for more info
Old Aug 11, 2007 | 09:12 PM
BILLETGRIP's Avatar
Default Re: (7rrivera7)
i would just get gsr mains and a arp stud kit for a gsr.
Old Aug 12, 2007 | 08:44 AM
pasaunde's Avatar
I didn't modify the main caps for the dowels, planning to keep the rpms south of 8K It's a DD and I'd like it to last a few years
Old Aug 12, 2007 | 10:20 AM
BILLETGRIP's Avatar
Default Re: (DonF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF &raquo;</TD></TR><TR><TD CLASS="quote"> How hard was it to machine the 3 LS caps for the dowel pins that tie all this together and make it work?</TD></TR></TABLE>
its pretty easy if you already have the girdle and access to a cnc mill or a manual mill with a boring bar. but you cant just drill and ream the existing holes because the drill will follow the bolt holes and they are not exactly in line with dowels that go into the block.
Old Aug 12, 2007 | 12:56 PM
DonF's Avatar
Default Re: (BILLETGRIP)
I know.
Old Aug 12, 2007 | 04:12 PM
BILLETGRIP's Avatar
Default Re: (DonF)
i figured YOU did but you never know someone else might not
Old Jul 5, 2009 | 05:56 PM
abusedvtec's Avatar
Default Re: Girdle for LSVTEC
so i have gsr girdle and close to good machine shop do i achine the bottom end or the girdle and i can still use the oil pan and pickup tube from gsr right
abusedvtec
Jul 6, 2009 08:02 AM
lurkin' eg
Feb 18, 2008 07:15 PM
7rrivera7
Aug 23, 2007 04:19 PM
xxmikexx206
Jan 8, 2007 09:08 AM
built562
May 11, 2003 06:39 PM
